Hello-
When I set my Horizontal Feature Constraint to be a feature definition of Matchline (or anything else), it always defaults back to Bridge Abutment. Even though when I use Matchline, it does adjust my corridor the way I want it to, and does not when I use a horizontal line with a feature definition of Bridge Abutment. So anyone else working in this file would automatically assume the program is looking for a bridge abutment feature, when in actuality it is responding to what I keyed in, a Matchline. Is this a bug? I noticed it in my own templates as well as the delivered as shown below. Any ideas?
Thank you
What version of the software are you using? That might help narrow down any bug fixes or known issues.
MaryB
You may want to file an official Service Ticket. I haven't seen anyone bring this up before, but there's always the chance it's an actual bug.
This was logged about a month ago.
https://communities.bentley.com/products/road___site_design/f/geopak-inroads-mx-openroads-forum/192057/ord-2020-r1---template-point---cannot-set-the-horizontal-feature-constraint
The constraint works, the dialog box just resets the drop down to the default every time you open the template point. We are sort of tip-toeing around this by having our constraint null points in their own template and then merging that template into the design template that we want to utilize them with, eliminating the need to open the point properties to define the constraint.
thanks, Robert. glad to hear I wasn't crazy. I'll be patient for now and await the service patch.
