My model file is in metric, but the design standard I want to utilize is in english units. I'm trying to determine if my geometry meets AASHTO design standards for a 25 mph road. My project is in the states. I have access to the Indian and UK standards. If anyone knows of the appropriate metric design standard I should utilize in place of the AASHTO design standard mentioned above, then I would appreciate the information.
In the 'C:\ProgramData\Bentley\OpenRoads Designer CE\Configuration\Organization-Civil\_Civil Default Standards - Metric\Dgnlib\Design Standards' folder i.e. the Metrc WorkSpace normally installed as part of ORD - contains a 2011 and 2018 DGNlib e.g. 'AASHTO Design Standards 2018 - Metric.dgnlib'.
Yes. It did. Still waiting on IT for permissions.
Mark, Are you aware of a non ORD metric version compatible with Power InRoads Select Series 4? We have the ORD metric version, but once we open the DGNlib it is translated to a new format and is no longer readable.
I am afraid not. Sorry I cannot help you on this. Hopefully someone will chip in with a solution.
Okay.
