I am following this video below on how to create a complex terrain model and my referenced models are not showing up under OpenRoads Model.
https://communities.bentley.com/products/road___site_design/w/road_and_site_design__wiki/35094/video-create-complex-terrain-model
I started with a 3d seed file and then I attached the existing terrain and the corridor files as 3d model references and they aren't showing up in "Referenced models" under OpenRoads Model. Any suggestions?
Megan
I closed the explorer OpenRoads window and reopened it and now they show up. Fixed.
I began experiencing this in 2019R2 and reported it as a defect when I was able to reproduce the issue in 20R1. It was assigned Defect Request 1080947.
I just ran into this today and lost an hour trying to get the RERENCED MODELS to populate. This included hitting the "refresh" button, detaching and reattaching the reference and finally restarting my computer. Nothing.
Then i closed ORD and purged copies in ProjectWise Explorer. That did the trick. When i re-opened ORD I was able to see the REFERENCED MODELS listing as actually having references to click on. Fun times.
still happening today....unable to find a fix
