How to take profile in Open Roads as show above.If it is possible please tell me procedure.
All that annotation will require Annotation groups and favorites. I believe the Bentley Learn website has courses and videos to teach, not only how to create a profile, but how to set up all the annotation settings to develop what you want.
MaryB
Dear Mary
Can you explain in detail
Yes, it is possible to create such a profile drawing.
You need to create an Annotation Group that defines the frames that are to be drawn (10 frames in your case). Each frame will use a predefined Text Favorite (e.g. Proposed Z, Chainage) to write the data. You will also need a Linear Annotation Group as you are annotating the profile line itself.
This is not something that can be explained in a simple post on this forum - it is explained in the WorkSpace Setup learning path , specifically "OpenRoads Designer Workspace Setup: Step 5 - Annotation"
https://learn.bentley.com/app/Public/ViewLearningPathDetails?lpId=111346
Dear Marnell,
I tried above procedure but I didn't get profile as above I asked.
Hi Mark,May I know how do we match the profile data back to their respective alignment if we have multiple profiles as shown above?
