How to use multiple annotation groups for horizontal and vertical annotations?
From what I can tell, plan and profile annotation groups are set in the base geometry file's feature symbology settings. My problem is, I have other exhibits that use the same alignment but I want to use a different annotation group for the plan and profile. Is there a way to use a different annotation group in an exhibit file when referencing in my base geometry file?
  • AH - finally the penny drops (for me! D'OH!) - correct. Sorry about that - my apologies.
  • Haha, its all good. It is hard to differentiate because they both just say Annotation Group. I wasn't as clear as I could have been.
  • One of the many features of ORD is that different WorkSpaces and WorkSets with their different Feature Definitions and Feature Symbologies is that the same alignment can be displayed many different ways.
    1. The drawing (1) is created in WorkSpace A and WorkSet B.  The Feature Definitions and Feature Symbologies are modified to Annotate correctly.
    2. Drawing (2) is created in WorkSpace A and WorkSet C and drawing (1) is referenced into it.  The Feature Definitions and Feature Symbologies for WorkSet C are modified to Annotate  drawing (1) alternately.
    3. This is one of the advantages of each WorkSet having the ability to over ride the Feature Definitions and Feature Symbologies and annotation of any other.
    David E. Stewart
    Calgary, Alberta
    ORD 2022R1
  • But I thought drawings were only supposed to belong to one workset?
    And this doesn't help when the drawings all belong to the same project, but need to appear differently on different sheets, does it? that sounds like I would need a workset for plan-profiles, and one for layouts, and one for site plans, and one for structure elevations - all using the same profile or the same alignment, but requiring different annotation. I may just be confused, but that's what I am required to produce in some cases. And I don't like the idea of carrying around a half dozen copies of the profile drawing just to have different annotations. Especially if any adjustments to that annotation for readability will get thrown back to "default" any time the profile updates.
    MaryB
    Power GeoPak 08.11.09.918
    Power InRoads 08.11.09.918
    OpenRoads Designer 2021 R2
  • MaryB,
        Let me start of by saying that this system is far from ideal, but it can be made, kicking and screaming to work.
        The WorkSet that the drawing that contains the annotation is in, can reference drawings that are in a different WorkSet.  Alignment A in WorkSet A referenced into Drawing B with Annotation for Construction.  Alignment A referenced into Drawing C in WorkSet B with Annotation for something else.  The problem with this method,is that your Feature Symbologies have to be different for the different WorkSets.  This is the problem with associating the annotation definition to the element and not being able to pick the annotation definition and then annotate the element as in SS2.
       Personally, I have found that if you try to force ORD to behave the same way as SS2, you are going to have a lot of (grief) problems.  They are 2 different software platforms.  They don't behave the same, there are features in both that I like, but I am finding out that ORD is better in more instances.  There are still features missing in ORD, so I still go back and forth, but less as time goes on.
    David E. Stewart
    Calgary, Alberta
    ORD 2022R1
