From what I can tell, plan and profile annotation groups are set in the base geometry file's feature symbology settings. My problem is, I have other exhibits that use the same alignment but I want to use a different annotation group for the plan and profile. Is there a way to use a different annotation group in an exhibit file when referencing in my base geometry file?
So I would need a workset for each "type" of drawing in my plan set?
I can see that causing all sorts of confusion with users. And how does that work for Sheet indexing? I'm still wrapping my head around worksets and it seems like it gets more complicated the further I go.
MaryB
This method is the way that I have went, with the creation of levels for the various types of annotation, biggest drawback is that if you do not have all the different styles set-up initially and then go back and add one, when you open a different drawing set there is all of a sudden an additional annotation set that needs to be turned off on every sheet. Or the first time you annotate an alignment the screen is flooded with multiple annotations.
Pleased to say that this is now in ORD 2021 R1
Mark
