Sorry am re posting again have not been answered.Template disobeys the slope ratio that have set
I have created a template with a slope ratio of 1:2 but it displays 1:3 how do i solve this tried several solutions but still yet failed to solve.
only on cut sections is where there is drain is displays 1:3 but on fill section it displays 1:2..
 on cut sections is as seen
and on fill section to the left displays fine but to the right the same problem exists
Please help me fix this am expecting to submit this two days if i will succeed on this...sorry my consultant needs this by tomorrow..if there is a possibility of any help i would be glad thank you
FINAL ROAD TEMPLATE.itl
The Templates am using are in the folder TYPE 1 8M WIDTH
Template Named : TYPE 1 (8M (LAYERS (0.35)
                              TYPE 2 (8M LAYERS (0.45)
                              TYPE 3 (8M LAYERS (0.5)
                              TYPE 5 (8M LAYERS (0.6)
                              TYPE 6 (8M LAYERS (0.65)
These are the templates that am using..
After fixing the issue it will be better for me to know what was the problem to avoid asking again...Thank you
  • We would have to see how your template is constructed in order to provide a knowledgeable response.
    What I see looks consistent with a 1:2 fill slope in your fill end condition and a 1:3 foreslope and 1:2 backslope in your cut end condition.  This could be wrong based on the actual construction of your template.
    Please share your template library (.itl).
  • FINAL ROAD TEMPLATE.itl
  • Your templates look fine.  I believe they are working as you intended.
    I believe the problem is in the cross section itself.   Note that the text in your cross section is not parallel to the slope like the 1:2 label is.  The cross section is annotating the slope between SHLDR_L(_L or _R) and DITCH_BACKSLOPE(_L or _R) which is exactly 1:3.  Make sure that the SHDR_AGGB_BOT_L(_L or _R) features are displayed in your cross sections so the annotation uses those points.
  • I tried this but it looks like there is formality of labeling  and they depend on each other cause whenever i turn them they label themselves randomly sometimes when turn off one it doesn't give me the slope ratios..am confused on this part have been working the labels for almost two days now but still yet no sign of anything.Please if you are able to help me in a way that can understand it could have been better... Thank you
Reply
  • In another post you mentioned you are using InRoads SS2, so my answer is based on that.
    Here I have annotated the segments between features in a cross section:
    Note that slopes are annotated between all of the selected features.
    Here is another shot of the same section, but not all features are selected in the cross section dialog.  Nevertheless slopes are annotated between all of the selected features (I have drawn in the red line for clarity).
    Keep in mind that the list will only show the crossing features that have been added to the cross section with the Update Cross Section task.
