Hello All,
Can you help me to fix this issue?
I have a DGN file trying to open with PowerGeopak,
when file is open, and i try to select on element, it bring PowerGeopak hanging out, crushing and shutdown.
These are the following messages i got
PS: I am using PowerGeopak SS10
Does this happen with other dgn's?
make sure there are no hanging geopak.exe processes running in windows (task manager)
delete your resource filesDelete everything under the 8.11 folder
C:\Users\ yourusername \AppData\Local\Bentley\powergeopak\8.11
try again
https://communities.bentley.com/products/road___site_design/w/road_and_site_design__wiki/15923/geopak-resource-files-how-to-remove-them-and-why
other dgn is workign fine but only that file.
even i tried this file on other machines, there is still error and crushing powergeopak
I can upload the exception.txt file if you want.
ok. send me the dgn (attach here) I can try and see if it can be fixed.
View online
You received this notification because you subscribed to the forum. To unsubscribe from only this thread, go here.
Flag this post as spam/abuse.
I can't attached or drop file here, but i uploaded to cloud and give you the link:
https://1drv.ms/u/s!AuCq8zHcRBxuhclcw21WGJiiQHB6og?e=UBjLzR
Note: When DGN is opening, when you click on View2 Existing profile and after that hit back to View1 Plan any elements, it keep crushing
