I generated plan sheets via named boundaries - but some of the elements from my attached reference files aren't being displayed in the sheet views - they're invisible. In other words, I can hover my cursor over and select the elements to view their properties, but I can't actually see them.
FWIW the problem isn't isolated to just one or two of my references; each reference has at least a few elements that aren't visible in the sheet.
Please advise.
Kevin:
Could it be as simple as the color of such elements being the same as the background color of your sheet file?
Mark
Hi Mark. No unfortunately, they are all different colors - green, pink, yellow, white/black.
Hmmm...
I have not had this issue at all with ORD. Hopefully someone else can chime in with some ideas. The only other thing that I can think of is a conflict with a particular display style. You might flip a few of these and see what happens. There must be a simple answer, I think.
