Is it posible to clip a reference file to make plan sheets while moving the reference file without its boundary? Without causing any harm to the base file you reference in for you project. ( If I reference in a base file start at STA. 0+00 to STA. 20+00 and cut my 1st sheet. Then copy the 1st sheet and uncheck the move with boundary then move that sheet to STA. 20+00 to STA. 40+00.) Would this change the base file?
Hello Jerry, what Bentley product and version are you using?
Hi Jesse ,Power GeoPak V8i Series 4
Thanks for confirming Jerry. I have moved your post to the appropriate product community forum where someone can assist you with this.
I'm not exactly following you...Could you be a little more descriptive about what steps you want to take and what you are trying to accomplish?
Generally, manipulating a reference file does nothing to the actual base file.
MaryB
Move reference in Ref manager and toggle move ref boundary
Chris
AECOM Roads UK&I Digital Engineering, Design & Solutions Lead | Sector Information Management Lead
Associate Director – Digital
OpenRoads Designer 10.12 | MicroStation 2023 | ProjectWise CE 10.3.4 | ContextCapture | ProjectWise PowerShell 2023 | ProjectWise WSG API | Generative Components | OpenBridge Designer 10.12
Civil 3D 2023 | Dynamo | Navisworks Manage
PowerShell | Visual Studio | Office 365 | Power Platform | Teams | SharePoint | Visio
Speckle | BIMVision | Revizto | Solibri
