How to delete a element or curve from a complex geometry by element?
Situations like realignment
You can place the "new" geometry and use Alt if prompted to select pieces of existing complex geometry to rule it to. Once you have the new geometry placed and are satisfied with it, use the Complex Redefine tool (Geometry > Common Tools) to redefine the complex geometry to use the new element(s) you have created.
Eddie Giese, PEProduction Manager | Senior Roadway EngineerLicensed in FL & PAACEC FDOTConnect Instructor on behalf of FDOT
Patel, Greene & Associates, LLC PowerGEOPAK V8i SS10 (08.11.09.918)OpenRoads Designer 2021 R2 (10.10.21.4)OpenRoads Designer 2020 R3 (10.9.0.91)ProjectWise Explorer CE 10.0.3.453LumenRT CE Update 14 (16.14.60.98)
I tried a lot as per your comment but I am unable to do realignment. Please give me a clear view with flowchart or a video link.
Hi Siva, check this video:
communities.bentley.com/.../video-using-the-complex-redefine-command-ss4
