How do I modify the elevation of a line or complex chain? In the properties the data is grayed and I cant change the value. I have a line with a 0 elevation and need to adjust.
Simplest way is to open a Profile Model for the element and then define a profile there, Set Active, and it will show up in your 3D View. If you have a constant elevation you'd like for the element in question, create a simple line profile that has a 0.00% slope at the desired elevation.
Eddie Giese, PEProduction Manager | Senior Roadway Engineer | AssociateLicensed in FL & PAACEC FDOTConnect Instructor on behalf of FDOT
Patel, Greene & Associates, LLC PowerGEOPAK V8i SS10 (08.11.09.918)OpenRoads Designer 2022 R3 (10.12.2.4)ProjectWise Explorer CE 10.0.3.453OpenRoads Conceptstation CONNECT Edition (10.0.16.84)LumenRT Pro CONNECT Edition (16.17.60.73)
Simple, maybe. Intuitive? I wouldn't have considered that...
MaryB
It's the ORD way. After spending a year and a half in Ss4 doing Site Design, I can't imaging any other way.
Well, that's not really true, but it is the first thought that comes to mind. And this is coming from one of the masters of the Edit Feature Point tool in InRoads Surface editing tools!
That was my go to tool for modifying and tweaking a DTM!
Just to clarify, are these civil elements in ORD? Are you working in a 3D model?
Couldn't agree more!
