Hi everyone,
I was wondering if it is possible to display off some components in the dynamic cross-section. There is some components that i dont want to be include in my volume calculations.
Martin
Displaying components is not the same as volume calculations.In the Feature Definition properties for meshes, check the 'Volume Option'. This is used to separate existing, design, unsuitable volumes - there is an option for 'None'. This may be where you should look to try get the results you want.
