Hi all,
I am trying to create contours and label them in a file from a DTM. After I load the file I go to Surface>View Surface>Contours, and hit Labels to insert a prefix and suffix;
However, when I hit apply, this is the label I end up with:
How do I get my prefix and suffix to stay as < and >?
Microstation V8i SS4 V08.11.09.845
Inroads
Leopold:
I suspect that the font which you are using uses ">" and "<". Change the font and see what happens; you have to cycle through various fonts to get what you need. We use a special variation of MicroStation system font 10. In that font "!" shows up as the centerline symbol you have here. Other characters are used to provide for other varied symbols.
Mark
Answer Verified By: Leopold Kisielinski
Yup that was it, thanks!
Most of the time, the simplest solution is the best!
