Can we use complex redefine to change the vertical geometry at particular chainages in profile model?
If not, please explain me briefly how can we resolve the above problem?
Yes you can use this command, I suggest you practice to realy understand how to use this command.
I tried a lot but it's not working. Complex redefine command is working in horizontal realignment. I have created two complex vertical geometries but unable to create a realignment in vertical geometry. please show me a way.
I needed to accomplish this but was having a lot of trouble getting a clean final profile. I found by exporting to LandXML and then re-importing as a new profile, I had a much easier to modify new profile. It might help to try this.
I would advise to drop the profiles and recomplex from elements.If it is sometime an issue while working with horizontal (because of an existing profile), but with the profile it is often possible without bad effect. Easier to manage and to keep a good and simple profile.
