Hi
Been using 2020 R1 to test the new "One Sheet per dgn" function to create on mass all my Drawings in ProjectWise.
While the tools works with "Out Of the Box" ProjectWise setups, it does seem to work with Advanced Wizard or ProjectWise setups with Document Naming Conventions.
How do I get 2020 R1 to activate Adv Wizard?
It would be good to get a tool in ORD like the one in OpenBuildings which helps name Models. etc in accordance with BS1192 or ISO19650.
It would be good if there was a dialog in the Drawing production tool that when working with PW activated and asked users to fill in Attributes needed for the entire set of Drawings. See Example of Attributes in ProjectWise:
If this is not possible can it be logged as an enhancement request?
Hi Chris, I filed the Enhancement 1086551:[ProjectWise] Advanced wizard with Naming Conventions
Answer Verified By: Chris Andrew
