I have marked culvert locations on my profile .dwg file and tried to attach as refernce to guide my vertical profile but the file not able to attach. i have tried to purge dwg file and reattach but failed. Please help me on.
What are you using to design your vertical profile - QVA or full Alignment? I assume you have an existing profile showing somewhere, and you want to reference in the culvert DWG. Is that correct?
Hello Mr.Mark,
I am using QVA. At first I have created vertical profile as per required design considerations. Then I have exported Longitudinal section of road profile through input method. In that exported .dwg file i have marked vertical lines at culvert locations with required raised level. I have tried to attach this marked .dwg file. But failed to do
What message are you getting when you try to reference the DWG?
And why not just mark the culvert positions on the MX profile? Why do you have to send it to DWG and AutoCAD? You have all the drawing tools in MX to do the exact same thing as you are doing in ACAD.
