I am posting the question here because I have only noticed this issue when I am using ORD. When I go to the View Toggle to open another view, inconsistently all of the other views will open as well. Is there a solution to this issue or is it just a bug?
Also, if there is any information on this please direct me to the post along with if I should post this elsewhere.
Thank you!
This is a common problem and has been for a long time. It is caused by a delay in registering the mouse click while the ORD code is spinning its wheels under the hood. If you pay close attention, you will see what seems to be happening:
I have found only the following workarounds. I don't know which is worst or best:
Robert Garrett Senior Consultant
www.envisioncad.com
Thank you for the insight!
