I am trying to figure out how to keep the help from going to the online help. I have set my preferences to not use online help but it still goes to the online help (see the first image below). Then when I click help I get the dialog box with explaining on how to turn this off (see the second image).
I have restarted the application many times and to no avail it always goes to the online help.
Any suggestions on how to fix this?
Gerald Piotrowski
Hi Gerald,
Try adding this variable to your workspace get to force it to use the local help (the preference option doesn't work):
MS_HELPLOAD_USEBROWSER = 0
Mark
OpenRoads Designer 2023 | Microstation 2023.2 | ProjectWise 2023
