I found this video https://www.youtube.com/watch?v=IH9ftlO2wdw&feature=emb_logo showing how to split an alignment into two separate alignments using SS3. Has this video been updated to show the process using ORD?
Gerald Piotrowski
Why not to use the Single Offset Partial command with an offset of 0?
See the help on the command: https://docs.bentley.com/LiveContent/web/OpenRoads%20Designer%20CONNECT-v9/en/GUID-B1133AAE-DB57-4C97-93DE-0A69AB162835.html
