Openrails conceptstation, when place the template with end condition through the alignment but cutting section is not visible, under the ground I cannot resolve this. Using grade resolve and alignment refresher but nothing happened. What should I do?
Hello Munkhuu, Can you verify the existing ground is set as the Active terrain?
How to set the active? its a not railway designer its a conceptstation.
PDF
Hello Munkhuu,Please find the attached file from Bentley LEARNserver which describes the required workflow.Let me know if that answers your question or not.Thank You
Thank you for your support that learner document is not helpful for resolve problem. Maybe its from software mistakes. Because when place the road its ok but railway has problems.
What did you use to create the 3sm? Is it a 3sm from Context Capture?
If yes, then you first need to run the ground extraction tool in the area that you want to place roads/tracks.
If no, please zip all files of your project and use the following link to upload your file. We will investigate why the track isn't clipping the terrain
https://bentley.sharefile.com/r-r655d06ca99443329
thanks,
Simon
