Hello, i drew lines and placed circular curves at PI points. Once i finished, it turned it into a complex geometry by "Complex by Element". But now i need to remove one of these circular curves and replace it with spiral curve-circular curve-spiral curve. So how can i do that ? I can not remove the circular curve i first placed.
Select the alignment and go to the Properties. At the top of the Properties dialog you can expand the Complex Elements. Find the curve in that geometry tree ... it will probably be listed as a Fillet between the two Lines. If you select that Fillet the Properties will open up below. Find the Back and Ahead Transitions (those are the spirals) and change the Type from None to Spiral and add your spiral criteria right there.
Answer Verified By: Engineer Yok
Thank you very much!
