Please can somebody let me know how to get the Point Feature Station Offset Evaluation Report to include cell names in the output. I have tried including a named point in the cell, but that has failed to work.
Is the cell name reported in the raw XML from the report? And what software are you using?
Hi Mark,
sorry for the delay in replying.
I'm using OpenRoads Designer and the cell name doesn't appear in the raw-xml.xsl.
Keith
If the cell name is not in the raw XML, it cannot get written to the XSL report. It sounds like you need to submit an enhancement request.
I remember asking about this a couple of years ago, but I don't think it ever got an Enhancement Request. I believe my thought, in lieu of getting the Cell Name exposed in the reportable XML docs was to assign an Item Type to the Cell and report that, but I don't think I ever tested it. I think that I came to the conclusion that if necessary, I'd just run a report for each cell type and use the file name to delineate what cell I had run the report on.
Thanks Robert and Mark for your replies. I've managed to mostly do what I wanted by applying the cells to a point feature definition and then reporting the point instead of the cell.
