I created the surface below from my corridor by selecting the 3D elements, but when I attempt to export the surface to a TIN, XML, DTM. I get the error mentioned in the title. How do I go about making this terrain valid? I have already removed rules from this surface.
Thank you
So you were able to get the TIN to triangulate and are you able to export it to a TIN or XML?
Sorry Chris I meant I CANNOT. When I try to force it to be recalculated, by changing the edge method for instance, the program freezes. I guess your terrain has an issue so if you could try to recreate a new one that'd worth a try.
