Superelevation Control
I am using horizontal alignments to control the horizontal location of my median and edge of pavement curbs.  Everything seems to work fine until I add superelevation control the the edge of pavement pivoting about the centerline.  I used a single control line to create the super.  After the super is added my left edge of pavement (which is the location of the super control) is not stretching correctly and even crosses the centerline.  Any thoughts on what is causing this?  I have double checked my point controls and everything seems to be OK.  I am using Inroads XM.
  • Sounds like your point constraints ( Vector Offset) within the template may be causing unexpected behavior. One way to test is to free some constraints in the Create Template command and move the points in and out and up and down to see if this may be causing the problem.
    If you run into problems and cannot debug this issue, let us know and we can take a look at your data.
    HTH
    Thomas
    This is a test
  • I removed the slope control I had on the outside edge of pavement and that fixed the problem.  Since I am controlling both the horizontal and vertical with alignments I don't need the control.  I believed point controls would overide the point constraints in the template.  Is this not the case?
  • You are correct about point controls overriding constraints, but which control overrides which constraint is dependent on the types of constraints.  For instance, if you have a Slope and Horizontal constraint on a point, and you apply a Horizontal control, then the Horizontal constraint will be replaced by the Horizontal control, but if you have a Slope and Vertical constraint, then the Slope constraint will be replaced with the Horizontal control.
    Also, when a Superelevation control is placed, there is an additional check for recursion on the pivot point, and one or more constraints may be removed from the pivot point if the pivot point is being controlled by the superelevated point.  This will sometimes give you strange results like the one you are seeing.
Reply
