I am trying to create a transition between an undivided four 2-lane road to divided four lane road. I am not modelling the curbs for the median though
I have two points for Median curb edges, ML and MR.
ML and MR are at zero distance from CL in undivided 2 lane road section.
The points are at half median width distance from CL in divided 4 lane section.
In template drop dialog box , I have checked the transition option between the 2 template drops.
In roadway modeler plan view, I right click the transition zone (highlighted in blue)
I click Edit transition
In the edit transition mid point window shown above, I am unable to free the horizontal constraint for ML and MR for the transition to happen. I am always getting option to edit point CL but nevertheless the other two points.
Please help me with the option to edit the constraints for the coinciding points. Is it possible Or should I have to try some other work around.
Hi Ramanan,
Points ML and MR at zero distance from CL in undivided 2 lane road section are not needed.
In your transition, map point ML and MR to your CL point.
You will then be able to delete constraints on points ML and MR, and then test them.
I hope this helps
Sanders
Answer Verified By: Ramanan R
Thanks a lot. That helped
