Use Feature Name Override
When I attempt to show cut/fill construction limits in plan view, I only see the separate feature definitions for cut/fill if I'm NOT using Use Feature Name Override, with gaps in between where it is transitioning.  If I DO use Feature Name Override, the complete complex element takes on its own feature definition, not designating where I have cut or fill.  I would like for the program to hold the cut symbology for cut and the fill symbology for fill for quick analyzation in plan view and still remain one feature by the override name.  Is this not possible?
I am in CONNECT 2020 Release 1 Update 8 - Version 10.08.00.88
