Open Roads - Terrain - Contour Labels
When labeling contours - can you set different levels to Minor and Major contour labels.  For example, create two dimension styles that would get applied to the entire terrain model - each dim style will correspond to the proper major and minor contour.
This is a feature within Civil 3D and I'm trying to see how to do this in Open roads without labeling each contour individually and manually switching styles.
