How we can generate Intersecting Alignment Stations report in Open roads Designer Connect.
Ilyas
I don’t believe there is currently a report for intersecting alignment stations in ORD, so I will make an enhancement request for you to have it added. I will post the log information below once it is created.
Jacob
If you would, post a description of your ideal Intersecting Alignment Stations report and why you want it, and I will include that information in the enhancement request.
Greetings Jacob,
Thanks and appreciate for reporting this issue to Bentley, Actually this is one of the requirement while creating the plan and profile drawings. The construction engineers and designers need the crossing element report showing stationing, northing, easting, elevation.
Also in the previous SS4 Openroads we are importing the crossing elements report as cogo points to annotate the crossing elements in the profile.
What is the workaround to annotate the crossing elements in the profile in Open Roads Designer.
Any Updates on the above issue?
I am not Ilyas, but it would be very helpful, on complicated projects to be able to select one alignment, and get a report of every other alignment that intersects it, with the stations of intersection for both the main (selected) alignment, and the auxilliary (intersecting) alignments.
This would streamline certain plan checking, where a report could be generated, and station intersection equations could be easily confirmed by the reviewer. Currently, they need to go into the drawings themselves and measure the distances or annotate the points themselves to confirm that the labels are correct.
In theory, labels are always generated automatically and so are always correct, but we may not be at that level of workspace completion for some time. And there is always the possibility that somebody will edit the text for whatever unknown reason, and the label will be out of sync. A report like this would streamline this sort of checking.
MaryB
