How we can generate Intersecting Alignment Stations report in Open roads Designer Connect.
Ilyas
Actualy I had not acess to the whole conversation at the time of my initial reply so the civil labeler is party the answer. There is no solution out of the box to do this, but with item type you can get the starting station of your line (or point) based on a reference alignement. So if you place a point or a starting line at every crossing "place" that you want (and then attach the item types) you could then make a microstation report that would get all those stations. And of course if you have that information you could also annotate it with civil labeler or annotation groups
Thanks Jeremie .
