Hi all,
I've been looking at ORD 2020 Release 2 and am trying to drop Terrains as described in the What's New of the Readme (https://docs.bentley.com/LiveContent/web/OpenRoads%20Designer%20CONNECT-v10/en/GUID-6343270D-95BD-4548-9D31-0CE16AD1F810.html).
The Drawing Drop command still results in the Terrain disappearing when you try to drop them, so is there some other method that is supposed to do this?
Mark
Looks like dropping Terrains using the Drop element command with Application elements ticked is now working in ORD 2020 R3...
Yes, The Raised defect 1026213 is been fixed in the ORD 2020 R3 and closed by developers. I would like to know if there is anymore we can upgrade within same feature.
Thanks Avdhoot,
Essentially the ability to also drop thematic display graphics to CAD elements is also something many users, including myself, need urgently for delivery to our clients. Just like this drop function, we need to be able to drop Thematic display graphics for export to other formats that are required.
I totaly Agree with Mark!
Hi Avdhoot,
ORD 2021 (10.10) has now lost this functionality and dropping Terrain functionality now has reverted to pre-ORD 2020 R3.
Can this Defect be reopened please.
Thank you so much for letting me know, I have created a new defect 1135873 which is also copied and linked with the older defect.
Thanks Avdhoot, this is something a lot of users really need quite often to convert Terrain graphics to non-DGN formats so im really hoping this can be re-applied for 2021 Release 2.
Not losing cells(drop) and text would be also nice. Not to mention contour annotations.
