Hi
Anyone experience failed update of OpenRoads Desigener
I am using Windows 10, fully updated
regards Sigfus
Got the same error
-Stian
Yep. Same error here. Even tried the layout method also error at the middle
Best Regards,
Kugan (Account Manager & Technical Adviser on MX and ORD)
Same issue;
Windows 8.1 fully updated
Openroads & Microstation allready installed
Update via connect client failed.
downloaded the installation file ord10080133en.exe and get a download error (failed to copy payload for OpenRoads Designer CONNECT Edition)
Follows installation log:
05-03T14:25:54]i001: Burn v3.11.1.2318, Windows v6.3 (Build 9600: Service Pack 0), path: C:\Users\FRANCI~1\AppData\Local\Temp\{8E73B20C-EA6F-4F95-ADEC-BEDBD4983056}\.cr\ord10080133en.exe[12CC:08AC][2020-05-03T14:25:54]i000: Initializing string variable 'BeExeName' to value 'OpenRoadsDesigner'[12CC:08AC][2020-05-03T14:25:54]i000: Initializing string variable 'LANGUAGE_3ccWin' to value 'ENU'[12CC:08AC][2020-05-03T14:25:54]i000: Initializing string variable 'BeApplicationToLaunchAfterInstallation' to value '[InstallDirectory]OpenRoadsDesigner\ActivationWizard.exe'[12CC:08AC][2020-05-03T14:25:54]i000: Initializing string variable 'BeApplicationToLaunchAfterInstallationArgs' to value '-productid:1000 -version:1000=[WixBundleVersion] -language:[LANGUAGE_3ccWin]'[12CC:08AC][2020-05-03T14:25:54]i000: Initializing string variable 'AddedPackagePageName' to value 'AddedPackagePage'[12CC:08AC][2020-05-03T14:25:54]i000: Initializing string variable 'PowerProductPackage_DiskSpaceCheckPath' to value '[InstallDirectory]'[12CC:08AC][2020-05-03T14:25:54]i000: Initializing string variable 'NotODPackageIdExtractionList' to value 'NDP462-KB3151800-x86-x64-AllOS-ENU;UsersAddedPackageInstaller'[12CC:08AC][2020-05-03T14:25:54]i000: Initializing string variable 'BeIF_PromptCloseApplication' to value 'openroadsdesigner'[12CC:08AC][2020-05-03T14:25:54]i000: Initializing string variable 'InstallDirectory' to value '[ProgramFiles64Folder]Bentley\OpenRoads Designer CONNECT Edition\'[12CC:08AC][2020-05-03T14:25:54]i000: Initializing string variable 'ConfigurationDirectory' to value '[CommonAppDataFolder]Bentley\OpenRoads Designer CE\'[12CC:08AC][2020-05-03T14:25:54]i000: Initializing string variable 'ConfigurationDirectory_V1' to value '[CommonAppDataFolder]Bentley\CONNECT Edition\'[12CC:08AC][2020-05-03T14:25:54]i000: Initializing string variable 'Custom_ConfigurationDirectory_Path' to value '[CommonAppDataFolder]Bentley\OpenRoads Designer CE\Configuration'[12CC:08AC][2020-05-03T14:25:54]i000: Initializing string variable 'LayoutSavePropertyList' to value 'InstallDirectory;ConfigurationDirectory;InstallDesktopShortcut;LumenRTInstallDirectory;LumenRTUserName;LumenRTCompanyName;SharedConfigurationDirectory'[12CC:08AC][2020-05-03T14:25:54]i000: Initializing string variable 'BePathPropertyList' to value 'InstallDirectory;ConfigurationDirectory;SharedConfigurationDirectory;LumenRTInstallDirectory'[12CC:08AC][2020-05-03T14:25:54]i000: Initializing string variable 'AddedPackageAvailablePropertyList' to value 'InstallDirectory;ConfigurationDirectory'[12CC:08AC][2020-05-03T14:25:54]i000: Initializing string variable 'BeKBBuddiName' to value 'MicroStation_KB_Requirements'[12CC:08AC][2020-05-03T14:25:54]i000: Initializing string variable 'PackageCacheHtmlHelpPageGuid' to value 'GUID-F0AAA55A-598A-408E-B326-342DA76E049D.html'[12CC:08AC][2020-05-03T14:25:54]i000: Initializing string variable 'BundleHelpConfigurationWhatsNewChildHtml' to value 'GUID-47192D89-C83C-49EF-9398-599ECDA8F97E.html'[12CC:08AC][2020-05-03T14:25:54]i000: Initializing string variable 'BeCustomRelatedBundleGuid' to value '{42EAA936-FD2F-483D-87EE-C6BE773942EC}'[12CC:08AC][2020-05-03T14:25:54]i000: Initializing string variable 'HDRPreviewExtension_x64_PossibleUserContextProductCode' to value '{9F7815C9-A323-4215-905C-73137D21BCC0}'[12CC:08AC][2020-05-03T14:25:54]i000: Initializing string variable 'BeBundleCulture' to value 'en'[12CC:08AC][2020-05-03T14:25:54]i000: Initializing string variable 'StandardPropertyList' to value 'AdminToolsFolder;AppDataFolder;CommonAppDataFolder;CommonFilesFolder;CommonFiles64Folder;CommonFiles6432Folder;ComputerName;Date;DesktopFolder;FavoritesFolder;FontsFolder;LocalAppDataFolder;LogonUser;MyPicturesFolder;PersonalFolder;ProgramFilesFolder;ProgramFiles64Folder;ProgramFiles6432Folder;ProgramMenuFolder;StartMenuFolder;StartupFolder;SystemFolder;TempFolder;TemplateFolder;WindowsFolder;WindowsVolume;'[12CC:08AC][2020-05-03T14:25:54]i000: Initializing string variable 'LayoutDirectory' to value '[WindowsVolume]BentleyDownloads\[WixBundleName]\'[12CC:08AC][2020-05-03T14:25:54]i000: Initializing string variable 'ProductsInstalledByBundle' to value 'NoProductList'[12CC:08AC][2020-05-03T14:25:54]i000: Initializing string variable 'BeBuildType' to value 'Release'[12CC:08AC][2020-05-03T14:25:54]i000: Initializing string variable 'BeNotBuildType' to value 'Beta'[12CC:08AC][2020-05-03T14:25:54]i000: Initializing string variable 'BeBundleShortName' to value 'OpenRoadsDesigner'[12CC:08AC][2020-05-03T14:25:54]i000: Initializing string variable 'BeWin64Bundle' to value 'yes'[12CC:08AC][2020-05-03T14:25:54]i000: Initializing string variable 'BeIFUseInternalResolver' to value '0'[12CC:08AC][2020-05-03T14:25:54]i000: Initializing string variable 'BeEulaFileName' to value 'Eula.htm'[12CC:08AC][2020-05-03T14:25:54]i000: Initializing string variable 'BundleHelpDocument' to value 'readMe_OpenRoadsDesigner_en.zip'[12CC:08AC][2020-05-03T14:25:54]i000: Initializing string variable 'VBA_LANGUAGE_PRGID_1033' to value '63644'[12CC:08AC][2020-05-03T14:25:54]i000: Initializing string variable 'VBA_LANGUAGE_PRGID' to value '63644'[12CC:08AC][2020-05-03T14:25:54]i000: Initializing string variable 'VBA_KB2803801_LANGUAGE_PRGID' to value '67804'[12CC:08AC][2020-05-03T14:25:54]i000: Initializing string variable 'LumenRTInstallDirectory' to value '[ProgramFiles64Folder]Bentley\Bentley LumenRT CONNECT Edition - Update 13'[12CC:08AC][2020-05-03T14:25:54]i000: Initializing string variable 'LumenRTDocumentDirectory' to value '[CommonAppDataFolder]Bentley\Bentley LumenRT CONNECT Edition - Update 13'[12CC:08AC][2020-05-03T14:25:54]i000: Initializing string variable 'LumenRTUserDocumentDirectory' to value '[PersonalFolder]Bentley\Bentley LumenRT CONNECT Edition'[12CC:08AC][2020-05-03T14:25:54]i000: Initializing string variable 'BeVarProductCode_ItgDgnDbImporter' to value '{AE4E79D2-D7DE-418F-9E7D-B58B62D7F4FA}'[12CC:08AC][2020-05-03T14:25:54]i000: Initializing string variable 'BeVarProductCode_ItgDgnDbImporter' to value '{AE4E79D2-D7DE-418F-9E7D-B58B62D7F4FA}'[12CC:08AC][2020-05-03T14:25:54]i000: Initializing string variable 'BeVarProductCode_PowerProductPackage' to value '{0F70BD02-5FF8-3AFB-83B1-AFD2E9B934E5}'[12CC:08AC][2020-05-03T14:25:54]i000: Initializing string variable 'BeVarProductCode_PowerProductPackage' to value '{0F70BD02-5FF8-3AFB-83B1-AFD2E9B934E5}'[12CC:08AC][2020-05-03T14:25:54]i000: Initializing string variable 'BeVarProductCode_CivilDesignWorkSpaceBundleModule' to value '{AFE29C4A-887E-3C8E-BC0A-E59F1C3D3458}'[12CC:08AC][2020-05-03T14:25:54]i000: Initializing string variable 'BeVarProductCode_CivilDesignWorkSpaceBundleModule' to value '{AFE29C4A-887E-3C8E-BC0A-E59F1C3D3458}'[12CC:08AC][2020-05-03T14:25:54]i000: Initializing string variable 'BeVarProductCode_GenerativeComponentsBundleModule' to value '{3807BB4A-0DD2-3E45-B1DB-6C02A6279EDD}'[12CC:08AC][2020-05-03T14:25:54]i000: Initializing string variable 'BeVarProductCode_GenerativeComponentsBundleModule' to value '{3807BB4A-0DD2-3E45-B1DB-6C02A6279EDD}'[12CC:08AC][2020-05-03T14:25:54]i000: Initializing string variable 'BeVarProductCode_PointTools32Extx86' to value '{C3AA62D1-5794-4A9F-9FEB-B687DC7C338C}'[12CC:08AC][2020-05-03T14:25:54]i000: Initializing string variable 'BeVarProductCode_PointTools32Extx86' to value '{C3AA62D1-5794-4A9F-9FEB-B687DC7C338C}'[12CC:08AC][2020-05-03T14:25:54]i000: Initializing string variable 'BeVarProductCode_DgnIFilterSetUpx64' to value '{2E873893-A883-4C06-8308-7B491D58F3D6}'[12CC:08AC][2020-05-03T14:25:54]i000: Initializing string variable 'BeVarProductCode_DgnIFilterSetUpx64' to value '{2E873893-A883-4C06-8308-7B491D58F3D6}'[12CC:08AC][2020-05-03T14:25:54]i000: Initializing string variable 'BeVarProductCode_DgnIndexer' to value '{833E82FD-B939-4E95-9E8A-44A57B5EBD0B}'[12CC:08AC][2020-05-03T14:25:54]i000: Initializing string variable 'BeVarProductCode_DgnIndexer' to value '{833E82FD-B939-4E95-9E8A-44A57B5EBD0B}'[12CC:08AC][2020-05-03T14:25:54]i000: Initializing string variable 'BeVarProductCode_DgnThumbnailProvier' to value '{74A8C1AF-75E5-4653-95AF-222725B7D877}'[12CC:08AC][2020-05-03T14:25:54]i000: Initializing string variable 'BeVarProductCode_DgnThumbnailProvier' to value '{74A8C1AF-75E5-4653-95AF-222725B7D877}'[12CC:08AC][2020-05-03T14:25:54]i000: Initializing string variable 'BeVarProductCode_HDRPreviewExtension_x64' to value '{9F7815C9-A323-4215-905C-73137D21BCC0}'[12CC:08AC][2020-05-03T14:25:54]i000: Initializing string variable 'BeVarProductCode_HDRPreviewExtension_x64' to value '{9F7815C9-A323-4215-905C-73137D21BCC0}'[12CC:08AC][2020-05-03T14:25:54]i000: Initializing string variable 'BeVarProductCode_ItgDgnDbImporter_v2' to value '{061ACA00-262E-48F8-9CF4-F796A0AF45A1}'[12CC:08AC][2020-05-03T14:25:54]i000: Initializing string variable 'BeVarProductCode_ItgDgnDbImporter_v2' to value '{061ACA00-262E-48F8-9CF4-F796A0AF45A1}'[12CC:08AC][2020-05-03T14:25:54]i000: Initializing string variable 'BeVarProductCode_DPH' to value '{0378B8FA-79D8-3736-8168-50A65B8EB857}'[12CC:08AC][2020-05-03T14:25:54]i000: Initializing string variable 'BeVarProductCode_DPH' to value '{0378B8FA-79D8-3736-8168-50A65B8EB857}'[12CC:08AC][2020-05-03T14:25:54]i000: Initializing string variable 'BeVarProductCode_VisualBasicCore' to value '{90120064-0070-0000-0000-4000000FF1CE}'[12CC:08AC][2020-05-03T14:25:54]i000: Initializing string variable 'BeVarProductCode_VisualBasicCore' to value '{90120064-0070-0000-0000-4000000FF1CE}'[12CC:08AC][2020-05-03T14:25:54]i000: Initializing string variable 'BeVarProductCode_VisualBasicLang' to value '{90F60409-7000-11D3-8CFE-0150048383C9}'[12CC:08AC][2020-05-03T14:25:54]i000: Initializing string variable 'BeVarProductCode_VisualBasicLang' to value '{90F60409-7000-11D3-8CFE-0150048383C9}'[12CC:08AC][2020-05-03T14:25:54]i009: Command Line: '-burn.clean.room=C:\Users\Francisco\Downloads\ord10080133en.exe -burn.filehandle.attached=324 -burn.filehandle.self=332'[12CC:08AC][2020-05-03T14:25:54]i000: Setting string variable 'WixBundleOriginalSource' to value 'C:\Users\Francisco\Downloads\ord10080133en.exe'[12CC:08AC][2020-05-03T14:25:54]i000: Setting string variable 'WixBundleOriginalSourceFolder' to value 'C:\Users\Francisco\Downloads\'[12CC:08AC][2020-05-03T14:25:54]i000: Setting string variable 'WixBundleLog' to value 'C:\Users\FRANCI~1\AppData\Local\Temp\OpenRoads_Designer_CONNECT_Edition_20200503142554.log'[12CC:08AC][2020-05-03T14:25:54]i052: Condition 'VersionNT64 > v6.1 OR (VersionNT64 > v6.0 AND VersionNT64 < v6.2 AND ServicePackLevel >= 1)' evaluates to true.[12CC:08AC][2020-05-03T14:25:54]i000: Setting string variable 'WixBundleName' to value 'OpenRoads Designer CONNECT Edition'[12CC:08AC][2020-05-03T14:25:54]i000: Setting string variable 'WixBundleManufacturer' to value 'Bentley Systems, Incorporated'[12CC:08AC][2020-05-03T14:25:54]i000: Loading managed bootstrapper application.[12CC:08AC][2020-05-03T14:25:54]i000: Creating BA thread to run asynchronously.[12CC:1B6C][2020-05-03T14:25:54]i000: Setting Culture Info to en[12CC:1B6C][2020-05-03T14:25:54]i000: Setting string variable 'BeSelectedLanguage' to value 'en'[12CC:1B6C][2020-05-03T14:25:54]i000: Setting string variable 'BeIFMainProcesCommandLineArgs' to value ''[12CC:1B6C][2020-05-03T14:25:54]i000: BentleyBundle Version 12.00.00.17[12CC:1B6C][2020-05-03T14:25:54]i000: TRY Set TLS 1.2[12CC:1B6C][2020-05-03T14:25:55]i000: Setting string variable 'WixExtractedTempFolder' to value 'C:\Users\Francisco\AppData\Local\Temp\{7180808C-2708-4140-95B2-B047582DB131}\.ba'[12CC:1B6C][2020-05-03T14:25:55]i000: Setting string variable 'BundleCurrentPath' to value 'C:\Users\Francisco\AppData\Local\Temp\{8E73B20C-EA6F-4F95-ADEC-BEDBD4983056}\.cr'[12CC:1B6C][2020-05-03T14:25:55]i000: Setting string variable 'WixBundleLayoutDirectory' to value 'C:\Users\Francisco\Downloads\'[12CC:1B6C][2020-05-03T14:25:55]e000: Using Layout File : C:\Users\Francisco\AppData\Local\Temp\{7180808C-2708-4140-95B2-B047582DB131}\.ba\Setup.lyt[12CC:1B6C][2020-05-03T14:25:55]i000: Setting VisualBasicCore InstallLevel to 1[12CC:1B6C][2020-05-03T14:25:55]i000: Setting VisualBasicCoreKB2803801 InstallLevel to 1[12CC:1B6C][2020-05-03T14:25:55]i000: Setting VisualBasicCoreKB3061498 InstallLevel to 1[12CC:1B6C][2020-05-03T14:25:55]i000: Setting VisualBasicCorepatch InstallLevel to 1[12CC:1B6C][2020-05-03T14:25:55]i000: Setting VisualBasicLang InstallLevel to 1[12CC:1B6C][2020-05-03T14:25:55]i000: Setting VisualBasicLangPackKB2803801 InstallLevel to 1[12CC:1B6C][2020-05-03T14:25:55]i000: Setting DotNet462Full InstallLevel to 1[12CC:1B6C][2020-05-03T14:25:55]i000: Setting VCRedistx64 InstallLevel to 1[12CC:1B6C][2020-05-03T14:25:55]i000: Setting BentleyConnectClient InstallLevel to 1[12CC:1B6C][2020-05-03T14:25:55]i000: Setting BentleyAdvisor InstallLevel to 1[12CC:1B6C][2020-05-03T14:25:55]i000: Setting ItgDgnDbImporter InstallLevel to 1[12CC:1B6C][2020-05-03T14:25:55]i000: Setting PowerProductPackage InstallLevel to 1[12CC:1B6C][2020-05-03T14:25:55]i000: Setting string variable 'PowerProductPackage.AddLocal' to value 'DefaultFeature,OptionalFeature,Configuration,FileAssociationFeature,TechPreview,expressiontoken,assetmanagertoken,pwcatalogtoken'[12CC:1B6C][2020-05-03T14:25:55]i000: Setting CivilDesignWorkSpaceBundleModule InstallLevel to 1[12CC:1B6C][2020-05-03T14:25:55]i000: Setting GenerativeComponentsBundleModule InstallLevel to 1[12CC:1B6C][2020-05-03T14:25:55]i000: Setting PointTools32Extx86 InstallLevel to 1[12CC:1B6C][2020-05-03T14:25:55]i000: Setting DgnIFilterSetUpx64 InstallLevel to 1[12CC:1B6C][2020-05-03T14:25:55]i000: Setting DgnIndexer InstallLevel to 1[12CC:1B6C][2020-05-03T14:25:55]i000: Setting DgnThumbnailProvier InstallLevel to 1[12CC:1B6C][2020-05-03T14:25:55]i000: Setting HDRPreviewExtension_x64 InstallLevel to 1[12CC:1B6C][2020-05-03T14:25:55]i000: Setting ItgDgnDbImporter_v2 InstallLevel to 1[12CC:1B6C][2020-05-03T14:25:55]i000: Setting DPH InstallLevel to 1[12CC:1B6C][2020-05-03T14:25:55]i000: Setting LumenRT2017 InstallLevel to 1[12CC:1B6C][2020-05-03T14:25:55]e000: LoadTestAutomationApp(): Failed to load test dll with error Object reference not set to an instance of an object.[12CC:1B6C][2020-05-03T14:25:55]e000: Failed for Package Id: PowerProductPackage_WinTabFeature Bootstrapper Application Data is not found for the Feature: PowerProductPackage_WinTabFeature[12CC:1B6C][2020-05-03T14:25:55]i000: Setting string variable 'BePrimaryProductName' to value 'OpenRoads Designer CONNECT Edition'[12CC:1B6C][2020-05-03T14:25:56]i000: Running with UI[12CC:1B6C][2020-05-03T14:25:56]i000: Display is set to Full[12CC:1B6C][2020-05-03T14:25:57]e000: Loading component /SetupPagesLib;v1.0.0.0;component/InstallDirectorySelectionUserControl.xaml[12CC:1B6C][2020-05-03T14:25:57]e000: Loading component /SetupPagesLib;v1.0.0.0;component/WelcomeDialogInstallUserControl.xaml[12CC:1B6C][2020-05-03T14:25:57]e000: Loading component /SetupPagesLib;v1.0.0.0;component/UninstallVerificationUserConstrol.xaml[12CC:1B6C][2020-05-03T14:25:57]e000: Loading component /SetupPagesLib;v1.0.0.0;component/PPCustomWorkSpacesUserControl.xaml[12CC:1B6C][2020-05-03T14:25:57]e000: Loading component /SetupPagesLib;v1.0.0.0;component/DeploymentImageSettingsControl.xaml[12CC:1B6C][2020-05-03T14:25:57]e000: Loading component /SetupPagesLib;v1.0.0.0;component/FeatureConfigUserControl.xaml[12CC:1B6C][2020-05-03T14:25:57]e000: Loading component /SetupPagesLib;v1.0.0.0;component/ProxySettingsUserControl.xaml[12CC:1B6C][2020-05-03T14:25:57]i000: Register callbak=ProxySettingsPage[12CC:1B6C][2020-05-03T14:25:57]i000: Display Page=ProxySettingsPage[12CC:1B6C][2020-05-03T14:25:57]i000: Cannot Display Page=ProxySettingsPage[12CC:1B6C][2020-05-03T14:25:57]e000: Loading component /SetupPagesLib;v1.0.0.0;component/ErrorUserControl.xaml[12CC:1B6C][2020-05-03T14:25:57]e000: Loading component /SetupPagesLib;v1.0.0.0;component/MaintenanceUserControl.xaml[12CC:1B6C][2020-05-03T14:25:57]e000: Loading component /SetupPagesLib;v1.0.0.0;component/RepairSelectionUserControl.xaml[12CC:1B6C][2020-05-03T14:25:57]e000: Loading component /SetupPagesLib;v1.0.0.0;component/AddedPackageUserControl.xaml[12CC:1B6C][2020-05-03T14:25:57]e000: Loading component /SetupPagesLib;v1.0.0.0;component/WarningUserControl.xaml[12CC:1B6C][2020-05-03T14:25:57]e000: Loading component /SetupPagesLib;v1.0.0.0;component/CompanionProductInstallDirSelectionUserControl.xaml[12CC:1B6C][2020-05-03T14:25:57]e000: Loading component /SetupPagesLib;v1.0.0.0;component/CompanionProductConfigurationSettingsUserControl.xaml[12CC:1B6C][2020-05-03T14:25:57]e000: Loading component /SetupPagesLib;v1.0.0.0;component/CompanionProductSelectionUserControl.xaml[12CC:1B6C][2020-05-03T14:25:57]e000: Loading component /SetupPagesLib;v1.0.0.0;component/CompanionProductFeatureSelectionUserControl.xaml[12CC:1B6C][2020-05-03T14:25:57]e000: Loading component /LumenRTExtension;v1.0.0.0;component/InstallDirSelection.xaml[12CC:1B6C][2020-05-03T14:25:57]e000: Loading component /LumenRTExtension;v1.0.0.0;component/LumenRTUserInformation.xaml[12CC:1B6C][2020-05-03T14:25:57]e000: Loading component /SetupPagesLib;v1.0.0.0;component/RedefineWixPackageCacheUserControl.xaml[12CC:08AC][2020-05-03T14:25:57]i100: Detect begin, 22 packages[12CC:08AC][2020-05-03T14:25:57]i000: PCRA: Checking running instances.[12CC:08AC][2020-05-03T14:25:57]i000: PCRA: Command Action - Install[12CC:08AC][2020-05-03T14:25:57]i000: PCRA: Command Display - Full[12CC:08AC][2020-05-03T14:25:57]i000: PCRA: No running instances.[12CC:08AC][2020-05-03T14:25:57]i000: PCRA: Exiting from prompt.[12CC:08AC][2020-05-03T14:25:57]i000: KBDetectBegin: Current Image is not running from a Deployment Image.[12CC:08AC][2020-05-03T14:25:57]i000: KBDetectBegin: Current action is allowed to executed for KB check. ActionName=Install[12CC:08AC][2020-05-03T14:25:57]i000: KBDetectBegin: Variable BeSkipKBCheck is not set to a value, hence, continuing with KB check.[12CC:08AC][2020-05-03T14:25:57]i000: Trying to connect to BUDDI, with NetworkCredentials=NULL. Retry Count = 1. Local Retry Count = 1[12CC:08AC][2020-05-03T14:25:58]e000: WaitForProxyAuthentication: Waiting for proxy authentication[12CC:08AC][2020-05-03T14:25:58]i000: Fetch BUDDI Key, RetryCount = 0[12CC:08AC][2020-05-03T14:25:58]e000: SetHeaders (): Added bootstrapper id in header, {e8283964-3996-478f-9b20-80b780c0101a}[12CC:08AC][2020-05-03T14:25:58]i000: Resolving Buddi Key. Attempt: 1[12CC:08AC][2020-05-03T14:26:04]i000: IsKBInstalled: Checking ManagementObjectSearcher with query=SELECT HotFixID FROM Win32_QuickFixEngineering.[12CC:08AC][2020-05-03T14:26:06]i000: IsKBInstalled: Got the collection of object with count=108.[12CC:08AC][2020-05-03T14:26:06]i000: IsKBInstalled: Checking for KB=KB2999226, in Title=KB2959936.[12CC:08AC][2020-05-03T14:26:06]i000: IsKBInstalled: KB=KB2999226 does not exist in Title=KB2959936.[12CC:08AC][2020-05-03T14:26:06]i000: IsKBInstalled: Checking for KB=KB2999226, in Title=KB2894852.[12CC:08AC][2020-05-03T14:26:06]i000: IsKBInstalled: KB=KB2999226 does not exist in Title=KB2894852.[12CC:08AC][2020-05-03T14:26:06]i000: IsKBInstalled: Checking for KB=KB2999226, in Title=KB2919355.[12CC:08AC][2020-05-03T14:26:06]i000: IsKBInstalled: KB=KB2999226 does not exist in Title=KB2919355.[12CC:08AC][2020-05-03T14:26:06]i000: IsKBInstalled: Checking for KB=KB2999226, in Title=KB2920189.[12CC:08AC][2020-05-03T14:26:06]i000: IsKBInstalled: KB=KB2999226 does not exist in Title=KB2920189.[12CC:08AC][2020-05-03T14:26:06]i000: IsKBInstalled: Checking for KB=KB2999226, in Title=KB2931358.[12CC:08AC][2020-05-03T14:26:06]i000: IsKBInstalled: KB=KB2999226 does not exist in Title=KB2931358.[12CC:08AC][2020-05-03T14:26:06]i000: IsKBInstalled: Checking for KB=KB2999226, in Title=KB2931366.[12CC:08AC][2020-05-03T14:26:06]i000: IsKBInstalled: KB=KB2999226 does not exist in Title=KB2931366.[12CC:08AC][2020-05-03T14:26:06]i000: IsKBInstalled: Checking for KB=KB2999226, in Title=KB2937220.[12CC:08AC][2020-05-03T14:26:06]i000: IsKBInstalled: KB=KB2999226 does not exist in Title=KB2937220.[12CC:08AC][2020-05-03T14:26:06]i000: IsKBInstalled: Checking for KB=KB2999226, in Title=KB2938772.[12CC:08AC][2020-05-03T14:26:06]i000: IsKBInstalled: KB=KB2999226 does not exist in Title=KB2938772.[12CC:08AC][2020-05-03T14:26:06]i000: IsKBInstalled: Checking for KB=KB2999226, in Title=KB2939153.[12CC:08AC][2020-05-03T14:26:06]i000: IsKBInstalled: KB=KB2999226 does not exist in Title=KB2939153.[12CC:08AC][2020-05-03T14:26:06]i000: IsKBInstalled: Checking for KB=KB2999226, in Title=KB2949621.[12CC:08AC][2020-05-03T14:26:06]i000: IsKBInstalled: KB=KB2999226 does not exist in Title=KB2949621.[12CC:08AC][2020-05-03T14:26:06]i000: IsKBInstalled: Checking for KB=KB2999226, in Title=KB2954879.[12CC:08AC][2020-05-03T14:26:06]i000: IsKBInstalled: KB=KB2999226 does not exist in Title=KB2954879.[12CC:08AC][2020-05-03T14:26:06]i000: IsKBInstalled: Checking for KB=KB2999226, in Title=KB2958262.[12CC:08AC][2020-05-03T14:26:06]i000: IsKBInstalled: KB=KB2999226 does not exist in Title=KB2958262.[12CC:08AC][2020-05-03T14:26:06]i000: IsKBInstalled: Checking for KB=KB2999226, in Title=KB2958263.[12CC:08AC][2020-05-03T14:26:06]i000: IsKBInstalled: KB=KB2999226 does not exist in Title=KB2958263.[12CC:08AC][2020-05-03T14:26:06]i000: IsKBInstalled: Checking for KB=KB2999226, in Title=KB2961072.[12CC:08AC][2020-05-03T14:26:06]i000: IsKBInstalled: KB=KB2999226 does not exist in Title=KB2961072.[12CC:08AC][2020-05-03T14:26:06]i000: IsKBInstalled: Checking for KB=KB2999226, in Title=KB2962140.[12CC:08AC][2020-05-03T14:26:06]i000: IsKBInstalled: KB=KB2999226 does not exist in Title=KB2962140.[12CC:08AC][2020-05-03T14:26:06]i000: IsKBInstalled: Checking for KB=KB2999226, in Title=KB2965142.[12CC:08AC][2020-05-03T14:26:06]i000: IsKBInstalled: KB=KB2999226 does not exist in Title=KB2965142.[12CC:08AC][2020-05-03T14:26:06]i000: IsKBInstalled: Checking for KB=KB2999226, in Title=KB2965500.[12CC:08AC][2020-05-03T14:26:06]i000: IsKBInstalled: KB=KB2999226 does not exist in Title=KB2965500.[12CC:08AC][2020-05-03T14:26:06]i000: IsKBInstalled: Checking for KB=KB2999226, in Title=KB2966826.[12CC:08AC][2020-05-03T14:26:06]i000: IsKBInstalled: KB=KB2999226 does not exist in Title=KB2966826.[12CC:08AC][2020-05-03T14:26:06]i000: IsKBInstalled: Checking for KB=KB2999226, in Title=KB2966828.[12CC:08AC][2020-05-03T14:26:06]i000: IsKBInstalled: KB=KB2999226 does not exist in Title=KB2966828.[12CC:08AC][2020-05-03T14:26:06]i000: IsKBInstalled: Checking for KB=KB2999226, in Title=KB2967917.[12CC:08AC][2020-05-03T14:26:06]i000: IsKBInstalled: KB=KB2999226 does not exist in Title=KB2967917.[12CC:08AC][2020-05-03T14:26:06]i000: IsKBInstalled: Checking for KB=KB2999226, in Title=KB2968296.[12CC:08AC][2020-05-03T14:26:06]i000: IsKBInstalled: KB=KB2999226 does not exist in Title=KB2968296.[12CC:08AC][2020-05-03T14:26:06]i000: IsKBInstalled: Checking for KB=KB2999226, in Title=KB2968599.[12CC:08AC][2020-05-03T14:26:06]i000: IsKBInstalled: KB=KB2999226 does not exist in Title=KB2968599.[12CC:08AC][2020-05-03T14:26:06]i000: IsKBInstalled: Checking for KB=KB2999226, in Title=KB2971203.[12CC:08AC][2020-05-03T14:26:06]i000: IsKBInstalled: KB=KB2999226 does not exist in Title=KB2971203.[12CC:08AC][2020-05-03T14:26:06]i000: IsKBInstalled: Checking for KB=KB2999226, in Title=KB2972103.[12CC:08AC][2020-05-03T14:26:06]i000: IsKBInstalled: KB=KB2999226 does not exist in Title=KB2972103.[12CC:08AC][2020-05-03T14:26:06]i000: IsKBInstalled: Checking for KB=KB2999226, in Title=KB2972213.[12CC:08AC][2020-05-03T14:26:06]i000: IsKBInstalled: KB=KB2999226 does not exist in Title=KB2972213.[12CC:08AC][2020-05-03T14:26:06]i000: IsKBInstalled: Checking for KB=KB2999226, in Title=KB2973114.[12CC:08AC][2020-05-03T14:26:06]i000: IsKBInstalled: KB=KB2999226 does not exist in Title=KB2973114.[12CC:08AC][2020-05-03T14:26:06]i000: IsKBInstalled: Checking for KB=KB2999226, in Title=KB2975061.[12CC:08AC][2020-05-03T14:26:06]i000: IsKBInstalled: KB=KB2999226 does not exist in Title=KB2975061.[12CC:08AC][2020-05-03T14:26:06]i000: IsKBInstalled: Checking for KB=KB2999226, in Title=KB2976627.[12CC:08AC][2020-05-03T14:26:06]i000: IsKBInstalled: KB=KB2999226 does not exist in Title=KB2976627.[12CC:08AC][2020-05-03T14:26:06]i000: IsKBInstalled: Checking for KB=KB2999226, in Title=KB2976978.[12CC:08AC][2020-05-03T14:26:06]i000: IsKBInstalled: KB=KB2999226 does not exist in Title=KB2976978.[12CC:08AC][2020-05-03T14:26:06]i000: IsKBInstalled: Checking for KB=KB2999226, in Title=KB2977629.[12CC:08AC][2020-05-03T14:26:06]i000: IsKBInstalled: KB=KB2999226 does not exist in Title=KB2977629.[12CC:08AC][2020-05-03T14:26:06]i000: IsKBInstalled: Checking for KB=KB2999226, in Title=KB2978002.[12CC:08AC][2020-05-03T14:26:06]i000: IsKBInstalled: KB=KB2999226 does not exist in Title=KB2978002.[12CC:08AC][2020-05-03T14:26:06]i000: IsKBInstalled: Checking for KB=KB2999226, in Title=KB2978122.[12CC:08AC][2020-05-03T14:26:06]i000: IsKBInstalled: KB=KB2999226 does not exist in Title=KB2978122.[12CC:08AC][2020-05-03T14:26:06]i000: IsKBInstalled: Checking for KB=KB2999226, in Title=KB2981580.[12CC:08AC][2020-05-03T14:26:06]i000: IsKBInstalled: KB=KB2999226 does not exist in Title=KB2981580.[12CC:08AC][2020-05-03T14:26:06]i000: IsKBInstalled: Checking for KB=KB2999226, in Title=KB2987107.[12CC:08AC][2020-05-03T14:26:06]i000: IsKBInstalled: KB=KB2999226 does not exist in Title=KB2987107.[12CC:08AC][2020-05-03T14:26:06]i000: IsKBInstalled: Checking for KB=KB2999226, in Title=KB2989647.[12CC:08AC][2020-05-03T14:26:06]i000: IsKBInstalled: KB=KB2999226 does not exist in Title=KB2989647.[12CC:08AC][2020-05-03T14:26:06]i000: IsKBInstalled: Checking for KB=KB2999226, in Title=KB2994290.[12CC:08AC][2020-05-03T14:26:06]i000: IsKBInstalled: KB=KB2999226 does not exist in Title=KB2994290.[12CC:08AC][2020-05-03T14:26:06]i000: IsKBInstalled: Checking for KB=KB2999226, in Title=KB2998527.[12CC:08AC][2020-05-03T14:26:06]i000: IsKBInstalled: KB=KB2999226 does not exist in Title=KB2998527.[12CC:08AC][2020-05-03T14:26:06]i000: IsKBInstalled: Checking for KB=KB2999226, in Title=KB2999226.[12CC:08AC][2020-05-03T14:26:06]i000: IsKBInstalled: KB=KB2999226 exist in Title=KB2999226.[12CC:08AC][2020-05-03T14:26:06]i000: IsKBInstalled: Checking ManagementObjectSearcher with query=SELECT HotFixID FROM Win32_QuickFixEngineering.[12CC:08AC][2020-05-03T14:26:07]i000: IsKBInstalled: Got the collection of object with count=108.[12CC:08AC][2020-05-03T14:26:07]i000: IsKBInstalled: Checking for KB=KB2919355, in Title=KB2959936.[12CC:08AC][2020-05-03T14:26:07]i000: IsKBInstalled: KB=KB2919355 does not exist in Title=KB2959936.[12CC:08AC][2020-05-03T14:26:07]i000: IsKBInstalled: Checking for KB=KB2919355, in Title=KB2894852.[12CC:08AC][2020-05-03T14:26:07]i000: IsKBInstalled: KB=KB2919355 does not exist in Title=KB2894852.[12CC:08AC][2020-05-03T14:26:07]i000: IsKBInstalled: Checking for KB=KB2919355, in Title=KB2919355.[12CC:08AC][2020-05-03T14:26:07]i000: IsKBInstalled: KB=KB2919355 exist in Title=KB2919355.[12CC:08AC][2020-05-03T14:26:07]i000: BeSkipKBCheck : [12CC:08AC][2020-05-03T14:26:07]i000: DetectBegin: e.Install=false, PlannedAction=Unknown, Setting InstallState=DetectedAbsent[12CC:08AC][2020-05-03T14:26:07]i000: SetCaseIndependentVariable: Check for VaribaleName=BeEmbeddedDisplay[12CC:08AC][2020-05-03T14:26:07]i000: SetCaseIndependentVariable: Check for VaribaleName=BeEmbeddedDisplay[12CC:08AC][2020-05-03T14:26:07]i000: SetCaseIndependentVariable: Check for VaribaleName=BeEmbeddedDisplay[12CC:08AC][2020-05-03T14:26:07]i000: SetCaseIndependentVariable: Check for VaribaleName=SkipPendingSystemRebootCheck[12CC:08AC][2020-05-03T14:26:07]i000: SetCaseIndependentVariable: Check for VaribaleName=SkipPendingSystemRebootCheck[12CC:08AC][2020-05-03T14:26:07]i000: SetCaseIndependentVariable: Check for VaribaleName=SkipPendingSystemRebootCheck[12CC:08AC][2020-05-03T14:26:07]i000: DetectBegin: Installed State of Package DetectedAbsent[12CC:08AC][2020-05-03T14:26:07]i000: Setting string variable 'BentleyAdvisorItInstalledVersion' to value '10.01.00.270'[12CC:08AC][2020-05-03T14:26:07]i000: Setting string variable 'BentleyConnectInstalledVersion' to value '10.00.18.025'[12CC:08AC][2020-05-03T14:26:07]i000: Registry key not found. Key = 'SOFTWARE\Bentley\Installed_LanguagePacks\{D11A86DD-FF26-4139-9C79-C1ABB4C8B5BF}'[12CC:08AC][2020-05-03T14:26:07]i000: Setting numeric variable 'LanguagePackRegistry' to value 0[12CC:08AC][2020-05-03T14:26:07]i000: Setting string variable 'LumenRTInstalledVersion' to value '16.13.23.16'[12CC:08AC][2020-05-03T14:26:07]i000: Setting string variable 'NetFramework46Version' to value '461814'[12CC:08AC][2020-05-03T14:26:07]i000: Product or related product not found: {1CC0EABA-3397-4893-833E-56BE22820105}[12CC:08AC][2020-05-03T14:26:07]i000: Setting numeric variable 'PRODSEARCHITG15INSTALLED' to value 2[12CC:1B6C][2020-05-03T14:26:07]i000: ErrorPage Code: 0[12CC:08AC][2020-05-03T14:26:07]i000: Setting string variable 'VC14_vcredist_x64_Installed' to value '1'[12CC:08AC][2020-05-03T14:26:07]i102: Detected related bundle: {419e067b-d3b4-4a9f-bc0c-5f2eb6fc01d8}, type: Upgrade, scope: PerMachine, version: 10.8.0.88, operation: MajorUpgrade[12CC:08AC][2020-05-03T14:26:07]i000: Upgrading: RelatedOperation=MajorUpgrade; RelationType=Upgrade[12CC:08AC][2020-05-03T14:26:07]i000: Setting string variable 'IsInstallDirectoryConfigurable' to value 'no'[12CC:08AC][2020-05-03T14:26:07]i000: AppendStringVariable (): Variable=BeUpgradingProductCodes doesn't exist, hence creating new variable with value {419e067b-d3b4-4a9f-bc0c-5f2eb6fc01d8}[12CC:08AC][2020-05-03T14:26:07]i000: Setting string variable 'BeUpgradingProductCodes' to value '{419e067b-d3b4-4a9f-bc0c-5f2eb6fc01d8}'[12CC:08AC][2020-05-03T14:26:07]i000: DetectedRelatedBundle ():Upgrade detected RelationType=Upgrade, Operation=MajorUpgrade, ProductCode={419e067b-d3b4-4a9f-bc0c-5f2eb6fc01d8}[12CC:08AC][2020-05-03T14:26:07]i106: Calculating patch applicability for target product code: {90120064-0070-0000-0000-4000000FF1CE}, context: Machine[12CC:08AC][2020-05-03T14:26:07]i106: Calculating patch applicability for target product code: {90F60409-7000-11D3-8CFE-0150048383C9}, context: Machine[12CC:08AC][2020-05-03T14:26:07]i052: Condition '(NetFramework46Version >= 394802)' evaluates to true.[12CC:08AC][2020-05-03T14:26:07]i052: Condition 'VC14_vcredist_x64_Installed' evaluates to true.[12CC:08AC][2020-05-03T14:26:07]i052: Condition 'BentleyConnectInstalledVersion >= v10.0.15.12' evaluates to true.[12CC:08AC][2020-05-03T14:26:07]i052: Condition 'BentleyAdvisorItInstalledVersion >= v10.1.0.135' evaluates to true.[12CC:08AC][2020-05-03T14:26:07]i103: Detected related package: {649694F4-40E8-328F-8C30-EB61096BC83C}, scope: PerMachine, version: 10.8.0.88, language: 0 operation: MajorUpgrade[12CC:08AC][2020-05-03T14:26:07]i000: DetectRelatedMsiPackage: Operation=MajorUpgrade[12CC:08AC][2020-05-03T14:26:07]i103: Detected related package: {CBC8C41F-D11C-3B5B-A662-99E93C10B06E}, scope: PerMachine, version: 10.8.0.88, language: 0 operation: MajorUpgrade[12CC:08AC][2020-05-03T14:26:07]i000: DetectRelatedMsiPackage: Operation=MajorUpgrade[12CC:08AC][2020-05-03T14:26:07]i103: Detected related package: {8E4DAAFD-D423-399F-862B-D9DB66066C8B}, scope: PerMachine, version: 10.8.0.88, language: 0 operation: MajorUpgrade[12CC:08AC][2020-05-03T14:26:07]i000: DetectRelatedMsiPackage: Operation=MajorUpgrade[12CC:08AC][2020-05-03T14:26:07]i052: Condition 'LumenRTInstalledVersion >= v16.13.23.16' evaluates to true.[12CC:08AC][2020-05-03T14:26:07]i101: Detected package: VisualBasicCore, state: Present, cached: Complete[12CC:08AC][2020-05-03T14:26:07]i101: Detected package: VisualBasicCoreKB2803801, state: Present, cached: Complete[12CC:08AC][2020-05-03T14:26:07]i105: Detected package: VisualBasicCoreKB2803801 target: {90120064-0070-0000-0000-4000000FF1CE}, state: Present[12CC:08AC][2020-05-03T14:26:07]i101: Detected package: VisualBasicCoreKB3061498, state: Present, cached: Complete[12CC:08AC][2020-05-03T14:26:07]i105: Detected package: VisualBasicCoreKB3061498 target: {90120064-0070-0000-0000-4000000FF1CE}, state: Present[12CC:08AC][2020-05-03T14:26:07]i101: Detected package: VisualBasicCorepatch, state: Present, cached: Complete[12CC:08AC][2020-05-03T14:26:07]i105: Detected package: VisualBasicCorepatch target: {90120064-0070-0000-0000-4000000FF1CE}, state: Present[12CC:08AC][2020-05-03T14:26:07]i101: Detected package: VisualBasicLang, state: Present, cached: Complete[12CC:08AC][2020-05-03T14:26:07]i101: Detected package: VisualBasicLangPackKB2803801, state: Present, cached: Complete[12CC:08AC][2020-05-03T14:26:07]i105: Detected package: VisualBasicLangPackKB2803801 target: {90F60409-7000-11D3-8CFE-0150048383C9}, state: Present[12CC:08AC][2020-05-03T14:26:07]i101: Detected package: DotNet462Full, state: Present, cached: None[12CC:08AC][2020-05-03T14:26:07]i101: Detected package: VCRedistx64, state: Present, cached: None[12CC:08AC][2020-05-03T14:26:07]i101: Detected package: BentleyConnectClient, state: Present, cached: None[12CC:08AC][2020-05-03T14:26:07]i101: Detected package: BentleyAdvisor, state: Present, cached: Complete[12CC:08AC][2020-05-03T14:26:07]i101: Detected package: ItgDgnDbImporter, state: Present, cached: Complete[12CC:08AC][2020-05-03T14:26:07]i101: Detected package: PowerProductPackage, state: Absent, cached: None[12CC:08AC][2020-05-03T14:26:07]i104: Detected package: PowerProductPackage, feature: DefaultFeature, state: Absent[12CC:08AC][2020-05-03T14:26:07]i104: Detected package: PowerProductPackage, feature: OptionalFeature, state: Absent[12CC:08AC][2020-05-03T14:26:07]i104: Detected package: PowerProductPackage, feature: PPDesktopShortcut, state: Absent[12CC:08AC][2020-05-03T14:26:07]i104: Detected package: PowerProductPackage, feature: Configuration, state: Absent[12CC:08AC][2020-05-03T14:26:07]i104: Detected package: PowerProductPackage, feature: FileAssociationFeature, state: Absent[12CC:08AC][2020-05-03T14:26:07]i104: Detected package: PowerProductPackage, feature: TechPreview, state: Absent[12CC:08AC][2020-05-03T14:26:07]i104: Detected package: PowerProductPackage, feature: expressiontoken, state: Absent[12CC:08AC][2020-05-03T14:26:07]i104: Detected package: PowerProductPackage, feature: assetmanagertoken, state: Absent[12CC:08AC][2020-05-03T14:26:07]i104: Detected package: PowerProductPackage, feature: pwcatalogtoken, state: Absent[12CC:08AC][2020-05-03T14:26:07]i101: Detected package: CivilDesignWorkSpaceBundleModule, state: Absent, cached: None[12CC:08AC][2020-05-03T14:26:07]i101: Detected package: GenerativeComponentsBundleModule, state: Absent, cached: None[12CC:08AC][2020-05-03T14:26:07]i101: Detected package: PointTools32Extx86, state: Present, cached: Complete[12CC:08AC][2020-05-03T14:26:07]i101: Detected package: DgnIFilterSetUpx64, state: Present, cached: Complete[12CC:08AC][2020-05-03T14:26:07]i101: Detected package: DgnIndexer, state: Present, cached: Complete[12CC:08AC][2020-05-03T14:26:07]i101: Detected package: DgnThumbnailProvier, state: Present, cached: Complete[12CC:08AC][2020-05-03T14:26:07]i101: Detected package: HDRPreviewExtension_x64, state: Present, cached: Complete[12CC:08AC][2020-05-03T14:26:07]i101: Detected package: ItgDgnDbImporter_v2, state: Present, cached: Complete[12CC:08AC][2020-05-03T14:26:07]i101: Detected package: DPH, state: Present, cached: Complete[12CC:08AC][2020-05-03T14:26:07]i101: Detected package: LumenRT2017, state: Present, cached: None[12CC:08AC][2020-05-03T14:26:07]i000: Detect complete Start[12CC:08AC][2020-05-03T14:26:07]i000: Setting string variable 'BePlannedAction' to value 'Install'[12CC:08AC][2020-05-03T14:26:07]i000: ItgDgnDbImporter AnalyzeFeatureConditions: LaunchAction=Install[12CC:08AC][2020-05-03T14:26:07]i000: ItgDgnDbImporter AnalyzeFeatureConditions: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False[12CC:08AC][2020-05-03T14:26:07]i000: ItgDgnDbImporter AnalyzeFeatureConditions: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False[12CC:08AC][2020-05-03T14:26:07]i000: PowerProductPackage AnalyzeFeatureConditions: LaunchAction=Install[12CC:08AC][2020-05-03T14:26:07]i000: PowerProductPackage AnalyzeFeatureConditions: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False[12CC:08AC][2020-05-03T14:26:07]i000: PowerProductPackage AnalyzeFeatureConditions: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False[12CC:08AC][2020-05-03T14:26:07]i000: PowerProductPackage_Configuration AnalyzeFeatureConditions: LaunchAction=Install[12CC:08AC][2020-05-03T14:26:07]i000: PowerProductPackage_Configuration AnalyzeFeatureConditions: BeforeAction Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=True[12CC:08AC][2020-05-03T14:26:07]i000: PowerProductPackage_Configuration AnalyzeFeatureConditions: AfterAction Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=True[12CC:08AC][2020-05-03T14:26:07]i000: PowerProductPackage_OptionalFeature AnalyzeFeatureConditions: LaunchAction=Install[12CC:08AC][2020-05-03T14:26:07]i000: PowerProductPackage_OptionalFeature AnalyzeFeatureConditions: BeforeAction Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=True[12CC:08AC][2020-05-03T14:26:07]i000: PowerProductPackage_OptionalFeature AnalyzeFeatureConditions: AfterAction Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=True[12CC:08AC][2020-05-03T14:26:07]i000: PowerProductPackage_FileAssociationFeature AnalyzeFeatureConditions: LaunchAction=Install[12CC:08AC][2020-05-03T14:26:07]i000: PowerProductPackage_FileAssociationFeature AnalyzeFeatureConditions: BeforeAction Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False[12CC:08AC][2020-05-03T14:26:07]i000: PowerProductPackage_FileAssociationFeature AnalyzeFeatureConditions: AfterAction Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False[12CC:08AC][2020-05-03T14:26:07]i000: PowerProductPackage_PPDesktopShortcut AnalyzeFeatureConditions: LaunchAction=Install[12CC:08AC][2020-05-03T14:26:07]i000: PowerProductPackage_PPDesktopShortcut AnalyzeFeatureConditions: BeforeAction Visible=True; IsChecked=False, IsSelectionEnabled=True, IsExpanded=False[12CC:08AC][2020-05-03T14:26:07]i000: PowerProductPackage_PPDesktopShortcut AnalyzeFeatureConditions: AfterAction Visible=True; IsChecked=False, IsSelectionEnabled=True, IsExpanded=False[12CC:08AC][2020-05-03T14:26:07]i000: PowerProductPackage_WinTabFeature AnalyzeFeatureConditions: LaunchAction=Install[12CC:08AC][2020-05-03T14:26:07]i000: PowerProductPackage_WinTabFeature AnalyzeFeatureConditions: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False[12CC:08AC][2020-05-03T14:26:07]i000: PowerProductPackage_WinTabFeature AnalyzeFeatureConditions: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False[12CC:08AC][2020-05-03T14:26:07]i000: PowerProductPackage_TechPreview AnalyzeFeatureConditions: LaunchAction=Install[12CC:08AC][2020-05-03T14:26:07]i000: PowerProductPackage_TechPreview AnalyzeFeatureConditions: BeforeAction Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=True[12CC:08AC][2020-05-03T14:26:07]i000: PowerProductPackage_TechPreview AnalyzeFeatureConditions: AfterAction Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=True[12CC:08AC][2020-05-03T14:26:07]i000: PowerProductPackage_assetmanagertoken AnalyzeFeatureConditions: LaunchAction=Install[12CC:08AC][2020-05-03T14:26:07]i000: PowerProductPackage_assetmanagertoken AnalyzeFeatureConditions: BeforeAction Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False[12CC:08AC][2020-05-03T14:26:07]i000: PowerProductPackage_assetmanagertoken AnalyzeFeatureConditions: AfterAction Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False[12CC:08AC][2020-05-03T14:26:07]i000: PowerProductPackage_expressiontoken AnalyzeFeatureConditions: LaunchAction=Install[12CC:08AC][2020-05-03T14:26:07]i000: PowerProductPackage_expressiontoken AnalyzeFeatureConditions: BeforeAction Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False[12CC:08AC][2020-05-03T14:26:07]i000: PowerProductPackage_expressiontoken AnalyzeFeatureConditions: AfterAction Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False[12CC:08AC][2020-05-03T14:26:07]i000: PowerProductPackage_pwcatalogtoken AnalyzeFeatureConditions: LaunchAction=Install[12CC:08AC][2020-05-03T14:26:07]i000: PowerProductPackage_pwcatalogtoken AnalyzeFeatureConditions: BeforeAction Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False[12CC:08AC][2020-05-03T14:26:07]i000: PowerProductPackage_pwcatalogtoken AnalyzeFeatureConditions: AfterAction Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False[12CC:08AC][2020-05-03T14:26:07]i000: CivilDesignWorkSpaceBundleModule AnalyzeFeatureConditions: LaunchAction=Install[12CC:08AC][2020-05-03T14:26:07]i000: CivilDesignWorkSpaceBundleModule AnalyzeFeatureConditions: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False[12CC:08AC][2020-05-03T14:26:07]i000: CivilDesignWorkSpaceBundleModule AnalyzeFeatureConditions: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False[12CC:08AC][2020-05-03T14:26:07]i000: GenerativeComponentsBundleModule AnalyzeFeatureConditions: LaunchAction=Install[12CC:08AC][2020-05-03T14:26:07]i000: GenerativeComponentsBundleModule AnalyzeFeatureConditions: BeforeAction Visible=False; IsChecked=False, IsSelectionEnabled=True, IsExpanded=False[12CC:08AC][2020-05-03T14:26:07]i000: GenerativeComponentsBundleModule AnalyzeFeatureConditions: AfterAction Visible=False; IsChecked=False, IsSelectionEnabled=True, IsExpanded=False[12CC:08AC][2020-05-03T14:26:07]i000: PointTools32Extx86 AnalyzeFeatureConditions: LaunchAction=Install[12CC:08AC][2020-05-03T14:26:07]i000: PointTools32Extx86 AnalyzeFeatureConditions: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False[12CC:08AC][2020-05-03T14:26:07]i000: PointTools32Extx86 AnalyzeFeatureConditions: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False[12CC:08AC][2020-05-03T14:26:07]i000: DgnIFilterSetUpx64 AnalyzeFeatureConditions: LaunchAction=Install[12CC:08AC][2020-05-03T14:26:07]i000: DgnIFilterSetUpx64 AnalyzeFeatureConditions: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False[12CC:08AC][2020-05-03T14:26:07]i000: DgnIFilterSetUpx64 AnalyzeFeatureConditions: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False[12CC:08AC][2020-05-03T14:26:07]i000: DgnIndexer AnalyzeFeatureConditions: LaunchAction=Install[12CC:08AC][2020-05-03T14:26:07]i000: DgnIndexer AnalyzeFeatureConditions: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False[12CC:08AC][2020-05-03T14:26:07]i000: DgnIndexer AnalyzeFeatureConditions: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False[12CC:08AC][2020-05-03T14:26:07]i000: DgnThumbnailProvier AnalyzeFeatureConditions: LaunchAction=Install[12CC:08AC][2020-05-03T14:26:07]i000: DgnThumbnailProvier AnalyzeFeatureConditions: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False[12CC:08AC][2020-05-03T14:26:07]i000: DgnThumbnailProvier AnalyzeFeatureConditions: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False[12CC:08AC][2020-05-03T14:26:07]i000: HDRPreviewExtension_x64 AnalyzeFeatureConditions: LaunchAction=Install[12CC:08AC][2020-05-03T14:26:07]i000: HDRPreviewExtension_x64 AnalyzeFeatureConditions: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False[12CC:08AC][2020-05-03T14:26:07]i000: HDRPreviewExtension_x64 AnalyzeFeatureConditions: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False[12CC:08AC][2020-05-03T14:26:07]i000: ItgDgnDbImporter_v2 AnalyzeFeatureConditions: LaunchAction=Install[12CC:08AC][2020-05-03T14:26:07]i000: ItgDgnDbImporter_v2 AnalyzeFeatureConditions: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False[12CC:08AC][2020-05-03T14:26:07]i000: ItgDgnDbImporter_v2 AnalyzeFeatureConditions: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False[12CC:08AC][2020-05-03T14:26:07]i000: DPH AnalyzeFeatureConditions: LaunchAction=Install[12CC:08AC][2020-05-03T14:26:07]i000: DPH AnalyzeFeatureConditions: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False[12CC:08AC][2020-05-03T14:26:07]i000: DPH AnalyzeFeatureConditions: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False[12CC:08AC][2020-05-03T14:26:07]i000: VisualBasicCore AnalyzeFeatureConditions: LaunchAction=Install[12CC:08AC][2020-05-03T14:26:07]i000: VisualBasicCore AnalyzeFeatureConditions: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False[12CC:08AC][2020-05-03T14:26:07]i000: VisualBasicCore AnalyzeFeatureConditions: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False[12CC:08AC][2020-05-03T14:26:07]i000: VisualBasicCoreKB2803801 AnalyzeFeatureConditions: LaunchAction=Install[12CC:08AC][2020-05-03T14:26:07]i000: VisualBasicCoreKB2803801 AnalyzeFeatureConditions: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False[12CC:08AC][2020-05-03T14:26:07]i000: VisualBasicCoreKB2803801 AnalyzeFeatureConditions: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False[12CC:08AC][2020-05-03T14:26:07]i000: VisualBasicCoreKB3061498 AnalyzeFeatureConditions: LaunchAction=Install[12CC:08AC][2020-05-03T14:26:07]i000: VisualBasicCoreKB3061498 AnalyzeFeatureConditions: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False[12CC:08AC][2020-05-03T14:26:07]i000: VisualBasicCoreKB3061498 AnalyzeFeatureConditions: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False[12CC:08AC][2020-05-03T14:26:07]i000: VisualBasicCorepatch AnalyzeFeatureConditions: LaunchAction=Install[12CC:08AC][2020-05-03T14:26:07]i000: VisualBasicCorepatch AnalyzeFeatureConditions: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False[12CC:08AC][2020-05-03T14:26:07]i000: VisualBasicCorepatch AnalyzeFeatureConditions: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False[12CC:08AC][2020-05-03T14:26:07]i000: VisualBasicLang AnalyzeFeatureConditions: LaunchAction=Install[12CC:08AC][2020-05-03T14:26:07]i000: VisualBasicLang AnalyzeFeatureConditions: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False[12CC:08AC][2020-05-03T14:26:07]i000: VisualBasicLang AnalyzeFeatureConditions: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False[12CC:08AC][2020-05-03T14:26:07]i000: VisualBasicLangPackKB2803801 AnalyzeFeatureConditions: LaunchAction=Install[12CC:08AC][2020-05-03T14:26:07]i000: VisualBasicLangPackKB2803801 AnalyzeFeatureConditions: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False[12CC:08AC][2020-05-03T14:26:07]i000: VisualBasicLangPackKB2803801 AnalyzeFeatureConditions: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False[12CC:08AC][2020-05-03T14:26:07]i000: DotNet462Full AnalyzeFeatureConditions: LaunchAction=Install[12CC:08AC][2020-05-03T14:26:07]i000: DotNet462Full AnalyzeFeatureConditions: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False[12CC:08AC][2020-05-03T14:26:07]i000: DotNet462Full AnalyzeFeatureConditions: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False[12CC:08AC][2020-05-03T14:26:07]i000: VCRedistx64 AnalyzeFeatureConditions: LaunchAction=Install[12CC:08AC][2020-05-03T14:26:07]i000: VCRedistx64 AnalyzeFeatureConditions: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False[12CC:08AC][2020-05-03T14:26:07]i000: VCRedistx64 AnalyzeFeatureConditions: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False[12CC:08AC][2020-05-03T14:26:07]i000: BentleyConnectClient AnalyzeFeatureConditions: LaunchAction=Install[12CC:08AC][2020-05-03T14:26:07]i000: BentleyConnectClient AnalyzeFeatureConditions: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False[12CC:08AC][2020-05-03T14:26:07]i000: BentleyConnectClient AnalyzeFeatureConditions: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False[12CC:08AC][2020-05-03T14:26:07]i000: BentleyAdvisor AnalyzeFeatureConditions: LaunchAction=Install[12CC:08AC][2020-05-03T14:26:07]i000: BentleyAdvisor AnalyzeFeatureConditions: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False[12CC:08AC][2020-05-03T14:26:07]i000: BentleyAdvisor AnalyzeFeatureConditions: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False[12CC:08AC][2020-05-03T14:26:07]i000: LumenRT2017 AnalyzeFeatureConditions: LaunchAction=Install[12CC:08AC][2020-05-03T14:26:07]i000: LumenRT2017 AnalyzeFeatureConditions: BeforeAction Visible=False; IsChecked=False, IsSelectionEnabled=True, IsExpanded=False[12CC:08AC][2020-05-03T14:26:07]i000: LumenRT2017 AnalyzeFeatureConditions: AfterAction Visible=False; IsChecked=False, IsSelectionEnabled=True, IsExpanded=False[12CC:08AC][2020-05-03T14:26:07]i000: Detection complete planned action: Install[12CC:08AC][2020-05-03T14:26:07]i000: DetectComplete (): Since action is =Install, performing CheckForAddOnRelatedBundle[12CC:08AC][2020-05-03T14:26:07]i000: CheckForAddOnRelatedBundle (): CURRENT Bundle Tag properties IsAddOn=False, IsLangPack=False, IsPatch=False, IsWin64=True, Classification=, ServicePack=0[12CC:08AC][2020-05-03T14:26:07]e000: CheckForAddOnRelatedBundle (): This product is not a Patch, LangPack or AddOn. Hence, not searching for related bundles[12CC:08AC][2020-05-03T14:26:07]i000: SessionMutex: Creating new SessionMutex[12CC:08AC][2020-05-03T14:26:07]i000: SessionMutex: Creating Mutex with Name={e8283964-3996-478f-9b20-80b780c0101a}-InstallMutex[12CC:08AC][2020-05-03T14:26:07]i000: SessionMutex: Created new SessionMutex with IsMutexOwned=False[12CC:08AC][2020-05-03T14:26:07]i000: WixInstallBA::SilentPlan[12CC:08AC][2020-05-03T14:26:07]i000: [12CC:08AC][2020-05-03T14:26:07]i000: Checking ADDLOCAL and REMOVE...[12CC:08AC][2020-05-03T14:26:07]i000: AutoCad Civil 3D ObjectEnabler:Searching[12CC:08AC][2020-05-03T14:26:07]i000: AutoCad Civil 3D ObjectEnabler: No registered MicroStation for object enabler[12CC:1B6C][2020-05-03T14:26:07]i000: ErrorPage Code: -1[12CC:08AC][2020-05-03T14:26:07]e000: baCustomConfigurationPath:Start[12CC:08AC][2020-05-03T14:26:07]e000: baCustomConfigurationPath:Custom path does not present configuation directory[12CC:08AC][2020-05-03T14:26:07]i199: Detect complete, result: 0x0[12CC:1B6C][2020-05-03T14:26:17]e000: Cannot release Mutex with error System.ApplicationException: Object synchronization method was called from an unsynchronized block of code. at System.Threading.Mutex.ReleaseMutex() at WixInstallBA.SessionMutex.ReleaseMutex()[12CC:08AC][2020-05-03T14:26:17]i500: Shutting down, exit code: 0xffffffff[12CC:08AC][2020-05-03T14:26:17]i410: Variable: AddedPackageAvailablePropertyList = InstallDirectory;ConfigurationDirectory[12CC:08AC][2020-05-03T14:26:17]i410: Variable: AddedPackagePageName = AddedPackagePage[12CC:08AC][2020-05-03T14:26:17]i410: Variable: BeApplicationToLaunchAfterInstallation = C:\Program Files\Bentley\OpenRoads Designer CONNECT Edition\OpenRoadsDesigner\ActivationWizard.exe[12CC:08AC][2020-05-03T14:26:17]i410: Variable: BeApplicationToLaunchAfterInstallationArgs = -productid:1000 -version:1000=10.8.1.33 -language:ENU[12CC:08AC][2020-05-03T14:26:17]i410: Variable: BeBuildType = Release[12CC:08AC][2020-05-03T14:26:17]i410: Variable: BeBundleCulture = en[12CC:08AC][2020-05-03T14:26:17]i410: Variable: BeBundleShortName = OpenRoadsDesigner[12CC:08AC][2020-05-03T14:26:17]i410: Variable: BeCustomRelatedBundleGuid = {42EAA936-FD2F-483D-87EE-C6BE773942EC}[12CC:08AC][2020-05-03T14:26:17]i410: Variable: BeEulaFileName = Eula.htm[12CC:08AC][2020-05-03T14:26:17]i410: Variable: BeExeName = OpenRoadsDesigner[12CC:08AC][2020-05-03T14:26:17]i410: Variable: BeIF_PromptCloseApplication = openroadsdesigner[12CC:08AC][2020-05-03T14:26:17]i410: Variable: BeIFMainProcesCommandLineArgs = [12CC:08AC][2020-05-03T14:26:17]i410: Variable: BeIFUseInternalResolver = 0[12CC:08AC][2020-05-03T14:26:17]i410: Variable: BeKBBuddiName = MicroStation_KB_Requirements[12CC:08AC][2020-05-03T14:26:17]i410: Variable: BeNotBuildType = Beta[12CC:08AC][2020-05-03T14:26:17]i410: Variable: BentleyAdvisorItInstalledVersion = 10.01.00.270[12CC:08AC][2020-05-03T14:26:17]i410: Variable: BentleyConnectInstalledVersion = 10.00.18.025[12CC:08AC][2020-05-03T14:26:17]i410: Variable: BePathPropertyList = InstallDirectory;ConfigurationDirectory;SharedConfigurationDirectory;LumenRTInstallDirectory[12CC:08AC][2020-05-03T14:26:17]i410: Variable: BePlannedAction = Install[12CC:08AC][2020-05-03T14:26:17]i410: Variable: BePrimaryProductName = OpenRoads Designer CONNECT Edition[12CC:08AC][2020-05-03T14:26:17]i410: Variable: BeSelectedLanguage = en[12CC:08AC][2020-05-03T14:26:17]i410: Variable: BeUpgradingProductCodes = {419e067b-d3b4-4a9f-bc0c-5f2eb6fc01d8}[12CC:08AC][2020-05-03T14:26:17]i410: Variable: BeVarProductCode_CivilDesignWorkSpaceBundleModule = {AFE29C4A-887E-3C8E-BC0A-E59F1C3D3458}[12CC:08AC][2020-05-03T14:26:17]i410: Variable: BeVarProductCode_DgnIFilterSetUpx64 = {2E873893-A883-4C06-8308-7B491D58F3D6}[12CC:08AC][2020-05-03T14:26:17]i410: Variable: BeVarProductCode_DgnIndexer = {833E82FD-B939-4E95-9E8A-44A57B5EBD0B}[12CC:08AC][2020-05-03T14:26:17]i410: Variable: BeVarProductCode_DgnThumbnailProvier = {74A8C1AF-75E5-4653-95AF-222725B7D877}[12CC:08AC][2020-05-03T14:26:17]i410: Variable: BeVarProductCode_DPH = {0378B8FA-79D8-3736-8168-50A65B8EB857}[12CC:08AC][2020-05-03T14:26:17]i410: Variable: BeVarProductCode_GenerativeComponentsBundleModule = {3807BB4A-0DD2-3E45-B1DB-6C02A6279EDD}[12CC:08AC][2020-05-03T14:26:17]i410: Variable: BeVarProductCode_HDRPreviewExtension_x64 = {9F7815C9-A323-4215-905C-73137D21BCC0}[12CC:08AC][2020-05-03T14:26:17]i410: Variable: BeVarProductCode_ItgDgnDbImporter = {AE4E79D2-D7DE-418F-9E7D-B58B62D7F4FA}[12CC:08AC][2020-05-03T14:26:17]i410: Variable: BeVarProductCode_ItgDgnDbImporter_v2 = {061ACA00-262E-48F8-9CF4-F796A0AF45A1}[12CC:08AC][2020-05-03T14:26:17]i410: Variable: BeVarProductCode_PointTools32Extx86 = {C3AA62D1-5794-4A9F-9FEB-B687DC7C338C}[12CC:08AC][2020-05-03T14:26:17]i410: Variable: BeVarProductCode_PowerProductPackage = {0F70BD02-5FF8-3AFB-83B1-AFD2E9B934E5}[12CC:08AC][2020-05-03T14:26:17]i410: Variable: BeVarProductCode_VisualBasicCore = {90120064-0070-0000-0000-4000000FF1CE}[12CC:08AC][2020-05-03T14:26:17]i410: Variable: BeVarProductCode_VisualBasicLang = {90F60409-7000-11D3-8CFE-0150048383C9}[12CC:08AC][2020-05-03T14:26:17]i410: Variable: BeWin64Bundle = yes[12CC:08AC][2020-05-03T14:26:17]i410: Variable: BundleCurrentPath = C:\Users\Francisco\AppData\Local\Temp\{8E73B20C-EA6F-4F95-ADEC-BEDBD4983056}\.cr[12CC:08AC][2020-05-03T14:26:17]i410: Variable: BundleHelpConfigurationWhatsNewChildHtml = GUID-47192D89-C83C-49EF-9398-599ECDA8F97E.html[12CC:08AC][2020-05-03T14:26:17]i410: Variable: BundleHelpDocument = readMe_OpenRoadsDesigner_en.zip[12CC:08AC][2020-05-03T14:26:17]i410: Variable: CommonAppDataFolder = C:\ProgramData\[12CC:08AC][2020-05-03T14:26:17]i410: Variable: ConfigurationDirectory = C:\ProgramData\Bentley\OpenRoads Designer CE\[12CC:08AC][2020-05-03T14:26:17]i410: Variable: ConfigurationDirectory_V1 = C:\ProgramData\Bentley\CONNECT Edition\[12CC:08AC][2020-05-03T14:26:17]i410: Variable: Custom_ConfigurationDirectory_Path = C:\ProgramData\Bentley\OpenRoads Designer CE\Configuration[12CC:08AC][2020-05-03T14:26:17]i410: Variable: HDRPreviewExtension_x64_PossibleUserContextProductCode = {9F7815C9-A323-4215-905C-73137D21BCC0}[12CC:08AC][2020-05-03T14:26:17]i410: Variable: InstallDirectory = C:\Program Files\Bentley\OpenRoads Designer CONNECT Edition\[12CC:08AC][2020-05-03T14:26:17]i410: Variable: IsInstallDirectoryConfigurable = no[12CC:08AC][2020-05-03T14:26:17]i410: Variable: LANGUAGE_3ccWin = ENU[12CC:08AC][2020-05-03T14:26:17]i410: Variable: LanguagePackRegistry = 0[12CC:08AC][2020-05-03T14:26:17]i410: Variable: LayoutDirectory = C:\BentleyDownloads\OpenRoads Designer CONNECT Edition\[12CC:08AC][2020-05-03T14:26:17]i410: Variable: LayoutSavePropertyList = InstallDirectory;ConfigurationDirectory;InstallDesktopShortcut;LumenRTInstallDirectory;LumenRTUserName;LumenRTCompanyName;SharedConfigurationDirectory[12CC:08AC][2020-05-03T14:26:17]i410: Variable: LumenRTDocumentDirectory = C:\ProgramData\Bentley\Bentley LumenRT CONNECT Edition - Update 13[12CC:08AC][2020-05-03T14:26:17]i410: Variable: LumenRTInstallDirectory = C:\Program Files\Bentley\Bentley LumenRT CONNECT Edition - Update 13[12CC:08AC][2020-05-03T14:26:17]i410: Variable: LumenRTInstalledVersion = 16.13.23.16[12CC:08AC][2020-05-03T14:26:17]i410: Variable: LumenRTUserDocumentDirectory = C:\Users\Francisco\Documents\Bentley\Bentley LumenRT CONNECT Edition[12CC:08AC][2020-05-03T14:26:17]i410: Variable: NetFramework46Version = 461814[12CC:08AC][2020-05-03T14:26:17]i410: Variable: NotODPackageIdExtractionList = NDP462-KB3151800-x86-x64-AllOS-ENU;UsersAddedPackageInstaller[12CC:08AC][2020-05-03T14:26:17]i410: Variable: PackageCacheHtmlHelpPageGuid = GUID-F0AAA55A-598A-408E-B326-342DA76E049D.html[12CC:08AC][2020-05-03T14:26:17]i410: Variable: PersonalFolder = C:\Users\Francisco\Documents\[12CC:08AC][2020-05-03T14:26:17]i410: Variable: PowerProductPackage.AddLocal = DefaultFeature,OptionalFeature,Configuration,FileAssociationFeature,TechPreview,expressiontoken,assetmanagertoken,pwcatalogtoken[12CC:08AC][2020-05-03T14:26:17]i410: Variable: PowerProductPackage_DiskSpaceCheckPath = C:\Program Files\Bentley\OpenRoads Designer CONNECT Edition\[12CC:08AC][2020-05-03T14:26:17]i410: Variable: PRODSEARCHITG15INSTALLED = 2[12CC:08AC][2020-05-03T14:26:17]i410: Variable: ProductsInstalledByBundle = NoProductList[12CC:08AC][2020-05-03T14:26:17]i410: Variable: ProgramFiles64Folder = C:\Program Files\[12CC:08AC][2020-05-03T14:26:17]i410: Variable: RebootPending = 0[12CC:08AC][2020-05-03T14:26:17]i410: Variable: StandardPropertyList = AdminToolsFolder;AppDataFolder;CommonAppDataFolder;CommonFilesFolder;CommonFiles64Folder;CommonFiles6432Folder;ComputerName;Date;DesktopFolder;FavoritesFolder;FontsFolder;LocalAppDataFolder;LogonUser;MyPicturesFolder;PersonalFolder;ProgramFilesFolder;ProgramFiles64Folder;ProgramFiles6432Folder;ProgramMenuFolder;StartMenuFolder;StartupFolder;SystemFolder;TempFolder;TemplateFolder;WindowsFolder;WindowsVolume;[12CC:08AC][2020-05-03T14:26:17]i410: Variable: VBA_KB2803801_LANGUAGE_PRGID = 67804[12CC:08AC][2020-05-03T14:26:17]i410: Variable: VBA_LANGUAGE_PRGID = 63644[12CC:08AC][2020-05-03T14:26:17]i410: Variable: VBA_LANGUAGE_PRGID_1033 = 63644[12CC:08AC][2020-05-03T14:26:17]i410: Variable: VC14_vcredist_x64_Installed = 1[12CC:08AC][2020-05-03T14:26:17]i410: Variable: VersionNT64 = 6.3.0.0[12CC:08AC][2020-05-03T14:26:17]i410: Variable: WindowsVolume = C:\[12CC:08AC][2020-05-03T14:26:17]i410: Variable: WixBundleAction = 5[12CC:08AC][2020-05-03T14:26:17]i410: Variable: WixBundleElevated = 0[12CC:08AC][2020-05-03T14:26:17]i410: Variable: WixBundleLayoutDirectory = C:\Users\Francisco\Downloads\[12CC:08AC][2020-05-03T14:26:17]i410: Variable: WixBundleLog = C:\Users\FRANCI~1\AppData\Local\Temp\OpenRoads_Designer_CONNECT_Edition_20200503142554.log[12CC:08AC][2020-05-03T14:26:17]i410: Variable: WixBundleManufacturer = Bentley Systems, Incorporated[12CC:08AC][2020-05-03T14:26:17]i410: Variable: WixBundleName = OpenRoads Designer CONNECT Edition[12CC:08AC][2020-05-03T14:26:17]i410: Variable: WixBundleOriginalSource = C:\Users\Francisco\Downloads\ord10080133en.exe[12CC:08AC][2020-05-03T14:26:17]i410: Variable: WixBundleOriginalSourceFolder = C:\Users\Francisco\Downloads\[12CC:08AC][2020-05-03T14:26:17]i410: Variable: WixBundleProviderKey = {e8283964-3996-478f-9b20-80b780c0101a}[12CC:08AC][2020-05-03T14:26:17]i410: Variable: WixBundleSourceProcessFolder = C:\Users\Francisco\Downloads\[12CC:08AC][2020-05-03T14:26:17]i410: Variable: WixBundleSourceProcessPath = C:\Users\Francisco\Downloads\ord10080133en.exe[12CC:08AC][2020-05-03T14:26:17]i410: Variable: WixBundleTag = BE;SP=0;LCID=1033;Win64=True;PID=2515[12CC:08AC][2020-05-03T14:26:17]i410: Variable: WixBundleUILevel = 4[12CC:08AC][2020-05-03T14:26:17]i410: Variable: WixBundleVersion = 10.8.1.33[12CC:08AC][2020-05-03T14:26:17]i410: Variable: WixExtractedTempFolder = C:\Users\Francisco\AppData\Local\Temp\{7180808C-2708-4140-95B2-B047582DB131}\.ba[12CC:08AC][2020-05-03T14:26:17]i007: Exit code: 0xffffffff, restarting: No
Many errors related to "copy payload" are due to existing program cache. Could you have a look in C:\ProgramData\package Cache and search for OpenRoads. Then if you find it, delete the folder. Something like: C:\ProgramData\Package Cache\{55F6D68A-D4F2-386D-BCC9-B28396E56609}v10.03.00.043
I even can't download it. I get the message:
Download failed, setup will retry after x seconds
