Roadway Designer Cross Sections (Geopak)
Anonymous
Anonymous
I am trying to get my ROW line to come in when I cut cross sections.  I can get it to show up in Roadway designer by using display references.  Does anybody know of a way to get these to show up when I cut cross sections?
Ross
  • Ross, Derricke is correct in that there is no direct way to do this.  But I saw a trick the other day that was really cool.  A user made a single line vertical component then drew a couple of crossing components on the top of the component line to represent the r/w label.  The trick is to make sure you set the components to not be included in the surface. There is a toggle for "do not triangulate" that you would assign to these.  The veritcal line component you can set to project to surface so that it will fall on the existing ground.
    Chuck
    This is a test
Reply
    Chuck
    This is a test
