Hi everyone, is there a way to generate both the cut and fill slope when it comes to terrain like this ? The problem is the ground treatment level varies from chainage to chainage, and mxroad allows input for one level datum where i can set where my fill slope can terminate. Ultimately I would need to get the cut and fill volume for this section for a example, and i supposed if i work this part out, the volume calculation should be alright using the stored section function ?
Thank you.
So what am I seeing here? You come down in Fill to a level (Z value) and then go back to ground?
yes, goes back to ground under pre-assigned earthwork style/strategy (in this case 1:1.5 with 5m high max)
Step 1. Create a model with only 1 string with defined level (+8.234 in the image).
Step 2. Use the model created in step 1 as your ground model when doing the fill interface, with Level Datum String as verge.
Step 3. Do cut interface up to ground model, using fill string from step 2 as the level datum string.
