Hello, "UseSprialLength" and "UseRunoutLength" are seen as false in the superelevation reports (as in the following picture). ORD doesn't use those while calculating the superelevation distances ? If it doesn't, how can i change it to involve runout length and spiral length in calculations ?
UseSpiral Length - If true, then wherever a spiral exists, it will be used as the transition length rather than the calculated transition. In this case, the percentTransitionOnTangent value will be ignored. The default value is true.
I believe the 'UseRunoutLength=False' means that normal crown is attained sooner as it does not add on a runout length.
How can i change both "false" to "true" ?
That sounds as if they are dependent on how your superelevation was defined?
MaryB
So my question is "how can i change the defination so it would use spiral and runout lenght ?"
Edit the Superelevation Rule file - via the dialog in ORD (or hack the XML in a text editor - not recommended if you are not familiar with XML)
