Is there a way to generate a Station/Offset report of Geometry points to an alignment? I've tried the Station/Offset report but I get the message that the points are invalid objects for the tool. Same for the Station/Base report. I've also tried the Point Feature Station Offset Elevation Report which allows me to select everything and bring up a report but all the reports are blank.
