can we use stecil command in openroads designer to drape multiple 2D surfaces onto terrain (or any 3d surface) simultaneously? Right now i have to use this commande for ONE 2D SURFACE at a time. I have multiple such 2D surfaces in my model hence it is very time consuming task. Is there any method where we can use such draping for multiple 2D surfaces simultaneously/
Thanks Mark,
this helps..
