1) I have assigned TL-shoulder edge feature def to shoulder edge point but that point is not displayed as linear feature in Plan view (2D view).
2) There is no issue in cross section and Default 3D view.
I am using Open roads Designerx64-10.04.00048 - 2018 release 2 version.
Thanks in advance
If the feature is in exactly the same plan position as top of kerb (for example), it will not be shown. This is working as it should be. In the 2D model, it only shows the top most feature.
Dear sir,
I agreed with your answer but the linear feature of kerb top point is also not displaying in plan.
How many features are there at the plan position? Does the 'Kerb top' have 'Create template geometry' turned on?
