I have the variables _USTN_WORKSETSDGNWSROOT and _USTN_WORKSETDGNWS set and they point to the dgnws in the Workset I am in, but when I add additional Properties, they show up in the first file I open but even with a Save Settings, they do not show up again on the Workset Properties. Is this a bug? There has been a lot of discussion in the CONNECT forum but not much here. Yes I am aware the Workset Propoerties are a function of CONNECT but is it a problem with the build ORD is created on?
Steve - I cannot reproduce this in OpenRoads Designer. It saves my workset properties to the dgnws. I would make sure that your dgnws file is in a read-write folder. Double check that those variables are defined properly by going to File > Configuration > Configuration Variables. Are you working within ProjectWise?
Has anyone ever found an answer to this? I am running into the same issue with 2022 Release 3 10.12. I used the _USTN_WORKSETSDGNWSROOT and _USTN_WORKSETDGNWS variables to store the .dgnws in a project-specific folder on our company network. I know the variables are working correctly because I am able to add and edit the sheet index and the .dgnws updates accordingly in the location I mapped it to. However, when I edit the workset properties the .dgnws does NOT update and the properties get deleted every time I close ORD.
