I was using Openroad Designer to design for Horizontal and Vertical geometry, however when i try to view 3D this error occur and im not able to view in 3D. Im new to this software, do anyone come across this error as well ?
Which version of ORD are you using? There are several, with different bug fixes along the way.
What are you doing when you "try to view 3D"? How are you trying to view the 3D model?
MaryB
Using this version -> (2020 RELEASE 1) 10.08.00.88I wanted to view my corridors design.
Are you using a function key to arrange views? There is a vba macro project in the Training and Examples workspace that will not be there if you are not in that workspace. We only recently discovered it and are in the process of incorporating it into our workspace.
I'm getting this error as well. I did a repair install which helped in the past but not this time. Using the standard right click open plan/3D 2021 R 2
Anybody else found a solution for this. This procedure has worked in the past.
Per another thread I deleted my users prefs. No joy.
