Im new to openroad designer. But I need to produce similar drawing from Openroad designer as what Mxroad produced.Info needed to be in the drawings will beExisting levelProposed LevelProposed level at road edgeVertical GeometryHorizontal GeometrySuperelvationChainage
The simple answer is yes - it you are talking about a profile drawing, here is an example.
Hi Mark, may I know is Openroads designer able to annotate the delta gradient as per MXroad shown in the photo below? Thanks
I know I can annotate start and end gradient - let me check on total change.
EDIT: At the moment, the answer is no.
Enhancement 1012027:[Annotation] Algebraic grade difference in profile
Thank you very much for the info and helping to file an enhancement request Mark.
