We are using linking codes with our survey but can't figure out how to close a shape. The issue is the starting point is also the last point in the second arc. Is there a way to assign two linking codes to a point? Or is there a way to close this shape?
In the Linking Codes dialog, you can specify the code to use to close the shape. (Survey Settings > Settings)
When I use CloseShape it looks like this instead of finishing the arc.
I am no surveyor - what happens if you use Close?
Then it just created a straight line back to the starting point
CloseShape
closes the ends of the linear feature by adding right angle at both ends and intersecting
Close
closes the Linear Feature back to the first point
Just saw this site.
https://communities.bentley.com/products/road___site_design/w/road_and_site_design__wiki/16136/point-coding-example
https://communities.bentley.com/products/road___site_design/w/road_and_site_design__wiki/42614/openroads-designer-survey-link-codes-close-and-closeshape
If I find anything more, I will post further.
