How to annotate super elevation profile in Long section box?
Please anyone help me in to display the Super elevation profile in Long section box.
Thanks in advance.
I am using Open roads Designerx64-10.04.00048 - 2018 release 2 version
  • The attached file is an example of how to annotate the superelevation in a profile. Import the xml into a Profile Annotation Group. The xml file was output from OpenRoads Designer 2020 Release 2. It uses two aliases, Left and Right to define what lanes are to be annotated.
    <?xml version="1.0" encoding="UTF-8"?>
    <AnnotationDefinitions>
      <AnnotationDefinition name="SuperElevation">
        <Frame xmlns="GeometryModel.00.00">
          <Where>
            <Displayed>True</Displayed>
            <Overlap>0</Overlap>
            <PositionOption>0</PositionOption>
            <Position>0</Position>
            <RowName />
          </Where>
          <TitleWidth>0.065</TitleWidth>
          <LeftMargin>0.006</LeftMargin>
          <RightMargin>0.0025</RightMargin>
          <IsTop>False</IsTop>
          <DrawBorder>True</DrawBorder>
          <RowNameList>
            <FrameRowReference>
              <RowClass>VoidFrameRow</RowClass>
              <PositionOption>1</PositionOption>
              <VoidFrameRow>
                <VoidFrameRow>
                  <RowHeight>0.0525</RowHeight>
                </VoidFrameRow>
              </VoidFrameRow>
            </FrameRowReference>
            <FrameRowReference>
              <RowClass>GraphFrameRow</RowClass>
              <GraphFrameRow>
                <GraphFrameRow>
                  <TitleText>
                    <Text> Superelevation</Text>
                    <Style>Profile - Annotation - Box Title</Style>
                    <InCellVerticalLocationOption>3</InCellVerticalLocationOption>
                    <VerticalValue>0</VerticalValue>
                    <InCellHorizontalLocationOption>2</InCellHorizontalLocationOption>
                    <HorizontalValue>0</HorizontalValue>
                    <Template>Annotation\Sheets\Profile\Draft_Profile_Text</Template>
                  </TitleText>
                  <RowHeight>0.0175</RowHeight>
                  <GraphType>3</GraphType>
                  <MaxValue>0.175</MaxValue>
                  <IntervalValue>0.001</IntervalValue>
                  <DrawMedianLine>True</DrawMedianLine>
                  <BorderTemplate />
                  <GraphLineTemplate />
                  <AlongSupport>Left</AlongSupport>
                  <WhereList>
                    <FrameRowWhere>
                      <Where>
                        <Where>1</Where>
                        <Support>Left</Support>
                        <HorizontalPointMask>0</HorizontalPointMask>
                        <VerticalPointMask>0</VerticalPointMask>
                        <CantPointMask>2</CantPointMask>
                        <ComponentMask>31</ComponentMask>
                        <ComponentOption>5</ComponentOption>
                        <IncrementValue xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:nil="true" />
                        <IncrementOption xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:nil="true" />
                        <IncrementSkipValue xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:nil="true" />
                        <StationOption xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:nil="true" />
                        <StationValue xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:nil="true" />
                        <StationSkipValue xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:nil="true" />
                        <ComponentIncrementOption xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:nil="true" />
                        <ComponentIncrementValue xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:nil="true" />
                      </Where>
                    </FrameRowWhere>
                  </WhereList>
                  <InverseSign xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:nil="true" />
                  <TopMargin xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:nil="true" />
                  <BottomMargin xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:nil="true" />
                  <MedianLineTemplate>Annotation\Sheets\Profile\Draft_Profile_Sheet_Minor_Grid</MedianLineTemplate>
                  <ConstantAmplitude xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:nil="true" />
                  <ConstantAmplitudeRatio xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:nil="true" />
                </GraphFrameRow>
              </GraphFrameRow>
            <FrameRowReference>
              <RowClass>TabulationFrameRow</RowClass>
              <TabulationFrameRow>
                  <TitleText>
                    <Text />
                    <Style />
                    <InCellHorizontalLocationOption>3</InCellHorizontalLocationOption>
                    <Template />
                  </TitleText>
                  <DrawBorder>False</DrawBorder>
                  <DrawLeaderLine>False</DrawLeaderLine>
                  <DrawVerticalLine>False</DrawVerticalLine>
                  <DrawVerticalTicks>True</DrawVerticalTicks>
                  <DrawHorizontalLine>False</DrawHorizontalLine>
                  <VerticalTicksPosition>1</VerticalTicksPosition>
                  <VerticalLineTemplate />
                  <VerticalTicksTemplate />
                  <BorderTemplate />
                  <HorizontalLineTemplate />
                  <LeaderLineTemplate />
                  <What>800</What>
                  <VerticalText>
                    <TextJustification>
                      <Angle>0</Angle>
                      <RadialOffset>0.0035</RadialOffset>
                      <TraverseOffset>0</TraverseOffset>
                    </TextJustification>
                    <Text />
                    <Style>Profile - Annotation - Box Values</Style>
                    <Favorite>Cross Section Tabular Data - Crossfall</Favorite>
                    <Template />
                    <ToSupport>[Active Profile]</ToSupport>
                    <Primitive>801</Primitive>
                    <ApplicationTag>Cross Slope</ApplicationTag>
                  </VerticalText>
                  <HasVerticalText>False</HasVerticalText>
                  <MiddleHorizontalText>
                    <TextJustification>
                      <Angle>0</Angle>
                    <Text />
                    <Template />
                  </MiddleHorizontalText>
                  <HasMiddleHorizontalText>True</HasMiddleHorizontalText>
                  <CollisionBehavior>
                    <CollisionBehaviorOption>0</CollisionBehaviorOption>
                    <MinimalClearance>1</MinimalClearance>
                    <LocationReference>1</LocationReference>
                    <ResizeDecrement>1</ResizeDecrement>
                    <ResizeMinimum>1</ResizeMinimum>
                    <ShiftLocation>2</ShiftLocation>
                    <ShiftSlantHeight>1</ShiftSlantHeight>
                    <ShiftLineTemplate />
                  </CollisionBehavior>
                  <WhereList>
                    <FrameRowWhere>
                      <Where>
                        <Where>1</Where>
                        <IncrementOption>0</IncrementOption>
                        <IncrementValue>10</IncrementValue>
                        <ComponentIncrementOption>0</ComponentIncrementOption>
                        <ComponentIncrementValue>0</ComponentIncrementValue>
                        <CantPointMask xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:nil="true" />
                      </Where>
                    </FrameRowWhere>
                  </WhereList>
                </TabulationFrameRow>
            <FrameRowReference>
                  <TitleText>
                    <Text />
                    <Style />
                    <Template />
                  </TitleText>
                  <VerticalTicksPosition>2</VerticalTicksPosition>
                  <BorderTemplate />
                  <What>800</What>
                  <VerticalText>
                    <TextJustification>
                      <RadialOffset>-0.0045</RadialOffset>
                      <Angle>0</Angle>
                    <Text />
                    <Template />
                    <AlongSupport>Right</AlongSupport>
                  </VerticalText>
                    <TextJustification>
                      <Angle>0</Angle>
                    <Text />
                    <Template />
                  <CollisionBehavior>
                  <WhereList>
                    <FrameRowWhere>
                      <Where>
                        <Where>1</Where>
                        <IncrementSkipValue>0</IncrementSkipValue>
                        <StationOption>0</StationOption>
                        <StationValue>0</StationValue>
                        <StationSkipValue>0</StationSkipValue>
                        <CantPointMask>0</CantPointMask>
                      </Where>
                    </FrameRowWhere>
                  </WhereList>
            <FrameRowReference>
              <GraphFrameRow>
                <GraphFrameRow>
                  <TitleText>
                    <Text />
                    <Style />
                    <Template />
                  </TitleText>
                  <DrawMedianLine>False</DrawMedianLine>
                  <BorderTemplate />
                  <WhereList>
                    <FrameRowWhere>
                      <Where>
                        <Where>1</Where>
                        <Support>Right</Support>
                        <CantPointMask>4</CantPointMask>
                      </Where>
                    </FrameRowWhere>
                  </WhereList>
                </GraphFrameRow>
              </GraphFrameRow>
          </RowNameList>
          <AliasList>
            <AliasDefinition>
              <Name>Left</Name>
              <Type>3</Type>
              <Method>1</Method>
              <IdString />
            </AliasDefinition>
            <AliasDefinition>
              <Name>Right</Name>
              <Type>3</Type>
              <Method>1</Method>
              <IdString />
            </AliasDefinition>
          </AliasList>
          <Name />
          <Template />
        </Frame>
      </AnnotationDefinition>
    </AnnotationDefinitions>
  • Dear sir,
     1) I have imported the xml file into my profile annotation group but I am getting result as in image 1. The values of cross-fall are showing as 0.00%       at super elevated portion.
     2) The cross section of the corridor at the same chainage showing the super elevation.
     3) What changes i have to do to get the super elevation schematic like in image 3.
      Thanks in advance.
  • Have you created the 'Aliases' to ask for the superelevation lanes? Have you created the text favorites? Have you opened the Annotation Group for editing to see what has be defined?
    The file I sent is an example - it was not created to draw your particular requirements..
  • Dear sir,
    1) I have created aliases to ask for super elevation lanes and also added graph line templates to super elevation left and right frames.
    2) I have used C/S tabular points-cross fall as Text favorites for cross fall points.
    Is there any editings need to be done in Super elevation>frames>graph> amplitude?
    Thanks in advance.
