I am able to append elements to the end of a current alignment, but cannot add (append) elements to the beginning. I have simplified geometry, but it still says Invalid geometry type. I want to see the existing profile for 1000' prior to where we were starting before. Any suggestions? Thanks.
I am working in the latest version of ORD
Katie, if you prefer to append an element to you alignment instead of using the Create 3dCut, please can you provide the alignment file and I'll have a look as the append tool should also work at the beginning of an alignment.
thank you, Marc. I found a workaround. It could be because my original begin point was snapped to a section corner. However, I did drop the rules on the complex alignment, so I'm not sure why it wouldn't accept another element at the beginning. If I encounter it again, I will surely reach out.
