How can I make the channel's complex elements get created on the default 2D plan view ?
A channel complex element from a template/corridor doesn't get created on the default 2D plan view. Other complex elements from the same template/corridor i.e. edges of pavements, sidewalks do appear. The channel's elements only get created on the 3D view. The channel's level indicates that  there are no elements  in Default 2D plan view.
