Is it possible to setup element templates per view i.e. default, plan, profile, cross section ? instead of a general setting for all views.
Yes. Look at the Feature Symbology. In the example shown, I am looking at the 'Linear' category. Note there is also a Profile category.
Hi Mark Marnell
I just change the colour used in my Element Template - and it was reflected in drawing and sheet models. Note that this only changing the Element Template in my local file - I should make that change in the DGNLIB for it to be available to all users.
That's a Surface Feature Definition. it's properties are different than linear feature definitions. Cross sections are cut from the 3D model, so the 3D property applies. There are a lot of nuances to Feature Definitions. Look in the Wiki pages or try googling Open Roads Features and you might find a PPTX or PDF that goes into all the details.
