Hello, when I check my cross-sections, some fill and cut slopes don't appear as in the picture below. Why does that happen and how can I fix it?
My second question is....where does ORD save sheets?
ORD saves sheets in the drawing in which you create them.
Are you sure that your side slope end condition solves in those sections? Most often when I "lose" my end conditions, it's because they actually can't solve at that particular location.
MaryB
well, I will send the DGN file to someone and I was wondering if he could see sheets directly or I have to the send sheet files which program saves somewhere, with the DGN file.
About the cross-section, when I click on "Edit Station" I see the cross-section normal as in the first picture. Also, when I check the alignment on the 3D view, those parts seem as the only line as in the second picture. So any advice?
There's not much I can do from a couple of pictures, but the fact that your model doesn't look right in that same area suggests that there is a problem with the sideslopes/end condition in that area. I'm not using ORD in production yet, so my experience is limited. Hopefully someone will be along to help you figure that out. What version (10.xx.xx.xx) are you using?
Yes, if you want to send your cross section sheets to someone you will have to send them the file you created the drawing & sheet models in.
Do they need the drawings, or could you just send them a PDF of the sheets?
I will send the file I created and drawing, so I just wondered if I also needed to send sheet files separately. I see I don't need to do so, from your answer.
The area in the second picture is from another spot, I wanted to show it as an example.
The sheets that are created are in the active file - unless you specify otherwise. Look at the Create Drawing dialog and you will see the following.
