I'm using InRoads SS4, and I was creating an alignment and the new cogo point dialog box popup out of reach and I can't move it anywhere. I tried some of the tips that are for MicroStation and didn't work. Any Help, please?
You might try what Chris recommended from this thread https://communities.bentley.com/products/road___site_design/f/geopak-inroads-mx-openroads-forum/59469/inroads-dialog-box/252662#252662
"In addition to this Explorer Show/Hide, the issue could also be the dialog is pushed off the screen or outside of the resolution.
The position of the dialogs is stored in HKEY_CURRENT_USER\Software\Bentley\InRoadsGroup\Applications\Version 8.11\DialogPos. When the you move a dialog, the new dialog position should be stored under this location if the user has Write privileges to the Registry. The next time the dialog is activated it should appear in the same position as it was previously.
Note that it is not recommended to make edits to the Registry but if you do, be very careful. You can close out of the product and delete this DialogPos to reset the position of all menu dialogs. The reload the product and the dialog should be reset to the default position."
For more information about the Road and Site design tools, visit the Road and Site design WIKI at:
http://communities.bentley.com/products/road___site_design/w/road_and_site_design__wiki
