I am trying to generate Plan & profile sheets following ODOT's example videos. I have generated the proposed alignments in the BK file and generated the GP drawings using the design2d file from the create design files application. I referenced in the alignments from the BK drawing and went through the steps using the place named boundary command. However when i get to the step to have the program "create drawing" I get an error that reads "Failed to attach savedview to model".
Has anyone else come across this issue?
Which version and which ODOT (Oregon, Ohio, Oklahama)?
Ohio DOT, and the open roads version is 10.08.00.88
we had someone opening project dgn files using a unc path. once they swapped to opening from a mapped drive this problem went away. maybe it's a bug?.. anyone else experience similar?
I don't recall any issues with dgn files but importing surface files - dtm or LandXML - will fail if I open them using a UNC path.
I am having this error too. I am working with North Dakota DOT.
I am cutting plan and profile sheets. I have been able to do so previously (same file, just another sheet).
I previously had issues with creating sheets, and after deleting personal.ucf, I was able to cut sheets. This is no longer working. Any thoughts on a solution would be appreciated.
ORD 10.07.03.18
