I need to create a 3-referenced line driveway civil cell that has to meet two criterias for its edge of pavement: -2% slope from the driveway centerline and ties into existing terrain where the ROW begins. To add an additional constraint, I selected a distance of 5 feet to be point where the profile goes from -2% slope offset to then linearly transition to tie into existing terrain where the right of way starts. I know how to do either or, but I run into issues when trying to accomplish both using the vertical geometry tools. I have noticed that when I use the Profile by Variable slope from element for my civil cell with a -2% slope from the centerline and stops 5 feet from the ROW line, the EOP profile locks in place and does not move dynamically when the civil cell is created and placed on other driveways. However when I use Profile by Slope from element for the entire element, I do not have this issue.
Before, I have been able to use the Profile by Slope from element or Profile Line between elements. In this case to combine them, I would need
Are there any other vertical geometry tools that I could be using to meet these constraints? If not, is there a setting that could be turned when using the profile by variable slope to not be locked in position?
This is what I have turned on for that tool.
Here are additional photos for reference.
Input with multiple profile tools
The civil cell it looks like this with Profile Between Points and Profile by Variable Slope From Element (2% down from centerline) on the linear portion and a parabolic transition for the curb.==>
Outcome with multiple profile tools
Centerline ==>
Profile Between Points and Profile by Variable Slope From Element ==>
Outcome with one profile tool
Profile by Slope from Element (2% down from centerline) ==>
Profile Between Points==>
